UFO woes part 2
   / UFO woes part 2 #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
OK,
(recap: problem is cant make the lift arm hydraulics work, not the 3pt which works fine)
I just changed out the switch that runs my lift arm hrdraulic piston, and no luck. Couldn't get it to do anything. I checked the fuse box again, nothing wrong there either. Made direct connections bypassing the switch, nothing.
So, where do I go from here? Inline fuse somewhere? There are 3 wires going to the switch, the center one was black on the old switch so I put it back in the middle. However, I think that black is usually a ground, correct? Anyway, I crossed the wires every combination and go nothing at all.
Any ideas would be most appreciated
thanks, Brett
   / UFO woes part 2 #2
Brett
Mine tilt only works when the 3 point is in the down position, because there is a little switch in the handle that controls it.
Could your switch have gotten bent, loose, or broke ?
Ernie
   / UFO woes part 2 #3
I was telling a friend that my tractor has a UFO tilt mechanism
you should have seen the look I got from everyone there.
You would of thought I looked like Art Bell. /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
   / UFO woes part 2 #4
They are really basic if you dont need the auto level part. If you are just using the joystick then it is just a 3 position switch and 2 electric valves. If you email me with a fax# I will fax you a page out of our owners manual that shows how to eliminate the electronic "self leveling" feature.
Aaron
Parts@HoyeTractor.com
(940) 438-0386
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
Gator XUV560S4 (A50324)
Gator XUV560S4...
AMG M 35 A2 C drop side 2 1/2 ton 6 x 6 truck (A50323)
AMG M 35 A2 C drop...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A52128)
Quick Attach Skid...
