Upgrade to self leveling loader?
   / Upgrade to self leveling loader? #1
FF117
West Central Illinois
Branson 4720h
What are the advantages/disadvantages of self leveling loaders? I have priced a new Branson tractor and can upgrade to a mechanical self leveling loader for about $300, but I can't decide if I want to. I've been told that you loose some rollback, but gain a little lifting capacity. Is this true? The Branson website lists the specs as nearly identical. I understand how the concept works, but have never operated a self leveling unit so it's difficult for me to decide. It would be nice to hear from owners who have operated both. Thanks for the help.
   / Upgrade to self leveling loader? #2
I am not sure on the rollback and lift capacity differences. Though I think this would very by brand/model.
The self-leveling is nice for pallet forks. You dont have to keep fiddling with the dump to get them level at different heights.
They are also nice for loading materials up high. Like loading a truck with dirt. With a Non-self leveling loader, if you scoop dirt a load of dirt, and then raise all the way without curling forward, a lot of material may end up on you/your hood.
I really cant think of any disadvantages of them other than more moving parts/grease points. But I'm sure others will chime in.
   / Upgrade to self leveling loader? #3
Only two disadvantages I know of are:
1) The leveling links will potentially reduce some of your visibity.
2) More pivot points to grease and maintain.
3) I have known some people to bend the leveling links by the bucket. They get rocks, branches etc. stuck between the bucket and the links and then when they curl the bucket back these links get bent.
If you are going to be using this loader for moving hay bales, I would definitely get the self leveling.
Roy
   / Upgrade to self leveling loader? #4
We removed them from our tractor last year after putting up with them for years. It increased the amount of material we could haul as stuff just fell out during transport. The feature just did not fit our needs as we did not use pallet forks or anything that would benefit from it.
   / Upgrade to self leveling loader? #5
The biggest drawback to self-leveling is the lack of roll back as you raise the bucket. At the ground surface, the roll back on a nonself-leveling (NSL) and self-leveling (SL) maybe a few degrees different but usually not significant. However, as you lift the FEL bucket, a NSL will roll the bucket back further due to the geometry of the lift. The makes it easier to transport heaping loads in the bucket without spilling the contents. (However, if lift load high, the contents may spill out the back of the bucket and onto the tractor.) The SL, will not roll back as the FEL is lifted and maintains the same degree of roll back as if it was on the ground. People who do a lot of bucket material work want the increased roll back as the FEL lifts, and therefore prefer NSL.
For other attachments such as pallet forks, man lift ect, the SL really shines because you don't need to make adjustments in the rollback as you lift or lower the FEL.
IMHO, wear, more grease zerks or bending of the SL arms is not an important factor to not purchase a SL loader. I have both SL and NSL loaders and it is a matter of choice depending on your tasks.
   / Upgrade to self leveling loader? #6
I have one self-leveling one and I would not do it again.
It is more money.
Roll angles are different
I can compensate for non-level loaders just fine.
D.
   / Upgrade to self leveling loader? #7
To miss-quote an old saying;
If Ya need to ask, you would most probably LIKE it (-:
MOST folk without a LOT of hours running loaders would find self leveling easier/nicer for most tasks, ESPECIALLY pallet fork work.
I often think that someone could start up a nice little basement business making kits of what ? the triangular swing plates, linkage rods, etc.
The design has usually been done by the factory, commonality of parts, etc.
Oh Ohh, patents and copyrights, DANG !!!
   / Upgrade to self leveling loader? #8
Surely self-leveling loaders have been around for more than twenty years? If so, then at least some designs should be off-patent.
BOB
   / Upgrade to self leveling loader? #9
I have the self leveling on my Kubota B21 and do not like it, although it's not a huge deal, I usually don't lift the bucket that high.
On the B21, it "self levels" in jerky steps. That tends to shake material out of the bucket if it's loose and dry.
I agree, there are times that I want more roll back than the SL allows.
I don't use pallet forks a whole lot (on my skid steer and M5040), but I have never missed the self leveling there. Again, I don't lift all that high usually and when I do, I can handle it manually if need be.
Ken
   / Upgrade to self leveling loader? #10
I think that it is a great feature at that price. Especially handy when doing pallet type work with. Self leveling will make all operations work a little easier. There is a reason that all industrial loaders and backhoes are made with self leveling buckets.
2012 PARK SEPARATOR (A47001)
2012 PARK...
2020 John Deere 870GP Articulated Motor Grader (A45336)
2020 John Deere...
2007 PARK TEST SEPARATOR (A47001)
2007 PARK TEST...
2011 Chevrolet Silverado 2500 Ext. Cab Pickup Truck (A45336)
2011 Chevrolet...
NEW Wolverine Skid Steer Trencher (A48289)
NEW Wolverine Skid...
2016 FREIGHTLINER M2 BOX TRUCK (A45677)
2016 FREIGHTLINER...
