Upgrading generator, need info
   / Upgrading generator, need info #1
Pilot
Veteran Member
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
Looking for a 7000-7500W generator, rated for about 9000W surge. Noise level and harmonic distortion would be nice to know--I'd like to be able sleep with it running or watch the tube or get on the computer.
So, how do I get the specs for THD & loudness? Generac, Honeywell, Powermate & Champion are all carried by Costco, but none of their websites list those specs, except Champion lists loudness. I shop Costco because their prices are generally a lot lower than HD or Lowes. However HD does have an ETQ brand unit that sounds good and they do list both specs, 70 dB and less than 5% THD.
Also, what other info is worthwhile knowing?
   / Upgrading generator, need info #3
Looking for a 7000-7500W generator, rated for about 9000W surge. Noise level and harmonic distortion would be nice to know...
I just did my own research on portable generators and decided on the 8kW Ridgid. (Ridgid rates theirs differently, it's 8kW continuous, 10kW peak.) First off, customer service from Home Depot was top notch. I ordered it one evening, got an email that it shipped the next day, and on the third day, a semi was at my driveway with the generator. And I live in a rural area. The purchase required me to make several calls to customer service (credit card issue), and each time, within a minute or two, I was talking to an English speaking person in Dallas. So I was impressed with the purchase end of the deal.
As for choosing Ridgid, their generators have decent reviews, and are not over priced. Generacs are expensive, have dismal reviews (look somewhere other than the Generac website), and my local small engine shop told me he could not get parts for a Generac. I'd have to go through a Generac dealer. The Ridgids have Yamaha (6.8 kW) and Subaru (8 kW) engines, easy to get parts for anywhere.
As for noise levels, I have a feeling whatever numbers you find may be questionable. (For starters, where is the meter reading taken? etc.) Ridgid says this 8kW is rated at 79.7 dB. I've had it running, have not made any noise level readings, but I'd say it's average noise level. Whatever average is...it's what noise I'd expect a generator this size to make. Not super loud, or super quiet, IMO. If you're really concerned about noise, I'd look into retro-fitting whatever you get with a secondary muffler(?)
I haven't had it hooked up to the house yet, but plan to soon.
Good luck, and have fun shopping. :)
- djb
   / Upgrading generator, need info #4
You should first decide what fuel you want, gas, NG/LP or diesel. Next what is the requirement, occasional backup, longer backup demands, portable or fixed ?
These are more critical in your decision than THD and sometimes noise. I started with a 7KW V twin gas generator. After I bought my Kubota tractor, I no longer needed gas on a regular basis at home, so I traded up to an 8 KW, air cooled, 3600 RPM diesel generator powered by a Deutz engine. I used it quite a few times with outages. A few years ago I upgraded to a 9.8 KW Kubota powered water cooled, 1800 RPM generator. Main reason was noise, reliability and lower fuel consumption.
Paul
   / Upgrading generator, need info #5
Lived with my Troy-bilt 7550 watt for 6 days last year after Irene. Ran the whole house just fine but would not run the washing machine. The washing machine would wash, but not spin. Later reading showed that others have had the same issue if the power was not real clean. Ran my old rear projection TV but I don't know if I would take the chance on my new 49" plasma.
Noise was not an issue, abeit it was at the other end of the house. I knew it was there but not overly so.
I picked up a Champion 2000 watt inverter that I would use for the new TV or extended lower demand appliances, like the fridge or freezer. (only takes a gallon for 10 hours)
   / Upgrading generator, need info #6
I second the Champion small generator. That means use it as your second generator during low load. It will very unlikely starts your well, but will keep your refrigerator running, tv, a few lights and save you a lot of gas. It is also extremely quiet since the engine slows down under light load.
   / Upgrading generator, need info #7
Not to hijack Pilots thread, but I'll expand a little.
I wired my wood burning furnace, circ pumps, controls and a couple of lights to a single circut then installed male/female plugs in line. This way I can plug into the little Champion generator and it will keep my furnace running for 10 hours before refueling. More than enough to get through the night or go to work and back. And it is very quite, at 100 ft (nearest neighbour) its almost below your hearing threshold.
That keeps all of your neighbours from showing up wanting to use your facilities.
I run the big genset while taking showers, cooking and so forth.
Troy-bilt 7550 takes 7.5 gallons for 10 hours, Champion takes 1.0 gallons for 10 hours.
Greg H
   / Upgrading generator, need info #8
I've looked casually into this myself. One option that makes sense is a PTO generator that runs from your tractor.
The noise would probably be less.
You get a lot of watts without having to buy an engine.
It can sit for a very long time and be ready to go because there are no long term storage issues as there are with gas engines and starting batteries.
You can easily move it to other locations for use there. This might be better than a portable genny that had to be lifted into a truck to go to your neighbors or out into the field, etc.
If you do go with a stand alone portable one, diesel is nice because the fuel can sit for long periods and be fine. Gas is a real problem. Right now I have a small Kubota diesel genny that's big enough to run my well or the fridge and some lights. But since it's diesel, starting it in the winter can be a challenge. My wife would never be able to do it if I was gone. But if she only had to start the tractor and plug in, no problem.
OP here. To clarify, I already have a Porter Cable generator which has a Briggs engine. Imagine running a car with no muffler--it's almost that loud. And the circuit panel is about 30 feet from our bedroom. We lose power 2 or 3 times a year (usually in the evenings, don't ask me why, I don't know) and every second year or so the outage lasts for a day or two, sometimes 4 or 5 days. Always in the winter and usually it's blowing and raining. Knowing those factors you can understand why noise is an issue and being able to run the TV while cooped up would be good.
I am considering LP, but will probably go with gas. I can get zero ethanol gas and as for storage, I just use it in the log splitter or my airplane to use it up & replace it with fresh (yes, it's OK to use in the plane and works better than avgas).
   / Upgrading generator, need info #10
I've got a generac that is in that size. It was a cheap generator, and while it's ok I'm not in love with it. Its had multiple problems (stupid stuff, but still problems) and doesn't even have 10 hours on it yet. It does do the job though, but is quite loud. Previously I had a 30+ year old honda, which was way more reliable and extremely quiet (could have a conversation next to it if you wanted), but was a tad too small. I'm looking at saving up and buying a honda in a larger size again, but they're 2 - 3x the price. Be careful of the DB ratings in the specs, they don't all rate them the same and some measure from a distance away, which isn't that accurate. Other specs I'd take a look at are the rated RPMS and whether it runs full speed all the time (loud, inefficient and wears quicker), or if it adjusts speed with demand (more expensive). You also can look at the specs for output voltage, ones with inverters will produce 'cleaner' power, which is better for computers and other sensitive equipment, though you can just buy a UPS and that'll make it safe for the computer. If you get one with a batter start make sure to get one that has a built in charger or alternator, the ones that you have to go and plug in every week for a few minutes aren't great and without careful diligence you have to replace the battery quickly.
2011 Ford F-250 Crew Cab Super Duty Pickup (A46502)
2011 Ford F-250...
John Deere WHP36A (A47307)
John Deere WHP36A...
Northstar 8000TFG Generator (A45336)
Northstar 8000TFG...
2013 BMW X5 xDrive35i AWD SUV (A46684)
2013 BMW X5...
2016 Cadillac ATS Sedan (A46684)
2016 Cadillac ATS...
1996 Jeep Grand Cherokee SUV (A46684)
1996 Jeep Grand...
