Use holes or slot in the telescopic stabilizers?
   / Use holes or slot in the telescopic stabilizers? #1
sevilla
New England
L3830
Hello, in the three point hitch there are two telescopic stabilizers, left and right. They have a few holes and one slot to insert the pin to limit the horizontal sway of the implement. My question is when to use the holes (min sway) and the slot (max sway). Thanks.
   / Use holes or slot in the telescopic stabilizers? #2
The slot is used when hooking up standard implements. It allows the arms to travel a bit to spread wide enough to slip to the outside of the implement's lower pins.
Most people just leave it there to allow for some sway or give so the implement or tractor are not damaged when something unforeseen is struck.
The other holes are for special applications or implements that are not of the standard construction.
   / Use holes or slot in the telescopic stabilizers? #3
Slots are used with implements which are ground engaging and need a limited amount of sway. Harrows, plows, subsoiler, etc... The holes are used when an implement will stay fixed and not sway. Mowers, scrapers, rear carrier, chipper, etc..
Thanks, that is what I needed to know.
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
Hayrack (A50515)
Hayrack (A50515)
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A52128)
2022 Quick Attach...
