Use of ether for starting
   / Use of ether for starting #1
daugen
Epic Contributor
New Hope PA
in between now
ether has been used for a long time to start old/cold diesels, but what about the use on gas engines?
I'm amazed how many YouTubers spray ether down the carb throat, when I was told the right way to do it, if you really had to do it,
was spray some on the air filter and let it be ingested that way.
Obviously ether is seriously flammable, explosive I'm sure, but so is gasoline. What harm does ether do?
Lot of comments on other threads about NOT using ether but the word sure hasn't gotten out.
Warranty techs say "oh, we can tell immediately and it will void your warranty". Why? They treat it like we are sticking an M80
down the carb.
With all of the ethanol issues leading to hard starting, is ether just the wrong choice 100% of the time? I use it very sparingly and not very often, but
always wondered why there was so much divergence in opinion on it.
   / Use of ether for starting #2
<snip>
With all of the ethanol issues leading to hard starting, is ether just the wrong choice 100% of the time?<snip>
If your running your diesel on ethanol you've got problems.
I've used WD40 SPARINGLY, BUT it's liable to explode my engine.
   / Use of ether for starting #3
A engine that has a hard time starting should be tuned. A diesel engine once you start using ether after a while it wont start with out it even when its warm. Using it on a gas engine is a accident waiting to happen. This is personal experince but do what you want.
agreed, I was referring to gas engines.
explode my engine + a accident waiting to happen.
I understand the concern, but why? Too volatile?
I never used ether on my diesel boat engines and I sure and heck aren't going to on my new Kubota, but
I'm just trying to understand why this often used starting aid is so hard on the engine.
   / Use of ether for starting #5
When ether ignites, it burns much more rapidly than gasoline or diesel, it's more like a small explosion. So when it ignites in the combustion chamber it hits the top of the piston while the piston is still moving upward. This causes severe stress on the pistons which can damage them.You can hear this happening, some people call it spark knock but the real name for this is detonation
You should never use ether on a light duty diesel for several reasons from the Diesel Blog
so this suggests that ether is ok on heavy duty diesels, since they are built so heavily that the extra stress on the pistons is tolerable?
I'm not advocating ether at all, just wondering why it can wreck an engine, and I guess volatility is the answer; it really is like a little M80 in the chamber.
And obviously gas engines are much lighter constructed, so the opportunity for terminal damage is greater for them. But...it is amazing how much ether is sprayed into every conceivable
type of engine on YouTube, and on some, they just keep spraying it in, like gasoline. Definitely makes the engine rev up...
Is WD40 a relatively safer alternative? Sure have plenty of that around. Must be less volatile.
   / Use of ether for starting #8
My 1981 John Deere 2240 has a factory port on the dash to screw in an ether can to give it a shot to aid in cold starting. Never had to use it, but it is there...
   / Use of ether for starting #9
I worked as a profession on Class eights, if you use either it will put gray streaks on the liners, the rings on an engine are actually cupped up, on the power stroke the preasure flattens them out, either will actually bend them down making them useless.
That is the reason on most engines there are marks for the top side of the rings. If you take apart a diesel engine the wear is on the lower edge, the top 70 % is just polished.
What I use to start a Diesel is Gas on a slightly damp rag, over the air filter. On a gas engine, plug it in.
On a side note Bio fuel is the very best fuel lubricity aditive there is better than every aditive you can buy and is a cetain booster.
Ethanol in gas does nothing as a disadvantage to starting, it does not hurt carburetor part. in you lawn mower.
Just a thought!
   / Use of ether for starting #10
Use of ether on a the small diesels has also been known to crush or collapse the ring lands on the pistons. Obviously not good.
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
TOOLBOX/FUEL TANK COMBO (A50854)
TOOLBOX/FUEL TANK...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A51039)
2021 John Deere...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
