hotchkiss
I have been looking for a used 8 foot heavy duty rear blade that I can pull behind a 90 hp tractor and not worry about tearing up. Is there such a thing out there? I have been looking a long time ha ha
Do you have the rear remotes for the hydraulics? Most of the rear blades that will stand up to your tractor will be hydraulically adjusted to angle, off set and tilt. A 9 footer would be a good match for your tractor. New you would be looking in the range of $3500-$5000. Here's a picture of mine, it is a great implement.
Good luck in your search for a used one that will work out for you.![]()
Yes, I have remotes.
What tractor is that you have?
I picked up this one from craigslist for $1200:
Its a woods RB850, which is rated for tractors up to 100hp and 10,000lbs.
It came with tilt and offset cylinders. I added angle.
They are out there, just have to be patient and keep looking.
Peter
