Used B6100
   / Used B6100 #1
JWE
SW Pennsylvania
Kubota BX2200
A fellow in my area is selling a B6100 with a 42 inch Woods deck. I haven't seen the tractor but here is what he told me about it:
manual trans (dual range)
2 WD
turf tires
18 HP 3 cyl. engine (the Kubota WEB page says 14 HP)
He said it is 14 years old (when did they stop selling new B6100?)
No hour meter (he said that he only used it to mow 1.2 acres)
paint is in excellent condition
He wants $2800 for it, that seems high to me. What are your thoughts?
   / Used B6100 #2
My price guide shows that B-6100 were made from 1978 to 1984so that would make it at least 20 years old. The guide also list the retail price range to be $2000-$4000. So he is right in there on price.
J.d.
   / Used B6100
Thanks for the information J. D.
Does the price guide differenciate between 2WD vs 4WD, Manual vs Hydro or engine HP?
Was there a 18 HP engine?
John
   / Used B6100 #4
JWE,
In anwer to your question </font><font color="blue" class="small">( What are your thoughts? )</font>, I thought I'd throw in some of my thoughts.
Here are some lead-in questions for you:
(1) How do you intend to use the tractor?
(2) Is the 42" mower a mid-mower or rear mower?
My thoughts:
(1) The price seems high to me, even if it is in the proper range mentioned in the other post. I would think the price would be okay if the tractor had either 4wd or hydrostatic transmission, and would definitely be a good price if it had both. I have seen several B7100 4wd/gear drive units for sale in the $3000 range, and the B7100 has a slightly larger (16hp) engine.
(2) My biggest complaint with my B7100 (4wd/manual trans) was the lack of live PTO. Mowing with my B7100's 48" mid-mower was pretty convenient (it operated off of a front mounted PTO), but operating with rear-mounted mowers (or other 3-point PTO equipment) was a royal pain unless operating in wide open areas that didn't require the tractor to change speeds or directions. EXCEPTION: Using a small 3-point hitch Kubota tiller wasn't too bad.
(3) It is my opinion that you will find the 2wd frustrating if you try to do much beyond mowing (plowing snow, etc).
(4) Parts will be generally available for the tractor and mid-mower, but you will not be able to find NEW ATTACHMENTS designed specifically for the B6100 (mid-mowers, FELs, etc).
(5) Based upon my experience with my B7100, I would say that the B6100 is a very good tractor. If you get the tractor, make sure you understand the unique operting requirements associated with its thermo-siphon cooling system. I have heard of (and personally experienced) engines with thermo-siphon cooling systems suffering overheat damage due to greater than 50% antifreeze mix in the coolant fluid. I (as well as others on this board) have made many posts on this subject (search for thermo-siphon).
Good Luck,
Kelvin
   / Used B6100 #5
JWE,
I just now looked at your profile to see that you already have a BX2200, so by knowing what your BX2200 will do in 2wd mode you'll already have an idea about the traction ability of the B6100. The BX2200 has a lot more hp and power steering over the B6100.
Regarding horsepower, I'm pretty sure that the B6100 is about 2hp less than the 16hp B7100. My statement is based upon the specifications listed in my shop manual which covers the B5100/B6100/B7100 tractors. While is doesn't list the engine horsepower, it does list the B6100's PTO hp at 11 hp and the B7100's PTO hp at 13hp. It also list all other engine specifications (bore, stroke, displacement, compression ratio, etc).
To help you look up B6100 data...
B6100E = 2wd manual transmission (like the one you are looking at)
B6100D = 4wd manual transmission
B6100HST-E = 2wd hydrostatic
B6100HST-D = 4wd hydrostatic
Kelvin
   / Used B6100
Kelvin
The mower is a belly mower. I would not be using it for mowing. I have a BX2200 that I use for mowing, snow removal and tilling. This would be a second tractor for me that I would mainly use for pulling a cart; hauling mulch around the yard and firewood out of the woods. I do not want to invest a lot of money for a 2nd tractor. I was hoping that I could pickup a 20 - 30 year old tractor for a very reasonable price.
John
   / Used B6100
One more question... is the B6100 about the same size and weight as the BX?
John
   / Used B6100 #8
again . what are u r intened uses for the tractor. kelvin pretty much says it all i wil just add that if u intend much snow removal, 2wd on a small cut is not very efective.
   / Used B6100
Frank
</font><font color="blue" class="small">( This would be a second tractor for me that I would mainly use for pulling a cart; hauling mulch around the yard and firewood out of the woods. I do not want to invest a lot of money for a 2nd tractor. )</font>
John
Kivel 3500 Lb Pallet Forks (A44502)
Kivel 3500 Lb...
2018 DODGE 5500 BUCKET TRUCK (A43004)
2018 DODGE 5500...
2023 Takeuchi TL10V2 (A44501)
2023 Takeuchi...
Quick Attach Plate (A44502)
Quick Attach Plate...
2015 John Deere 4052R Utility Tractor (A44571)
2015 John Deere...
2023 Bobcat E32i Mini Excavator (A44391)
2023 Bobcat E32i...
