Used Disc; Worth?
   / Used Disc; Worth? #1
Phred
Veteran Member
Arkansas
TN70D, 4wd, 16x16 trans
Guys,
Found an old beat up 3 point disc. Its about 7', although I did not measure it.
Very little paint left, but for these types of units I figure an old rusty model still has value.
At any rate I could easily sand blast and paint it.
How much would you buy or sell one of these for?
Fred
   / Used Disc; Worth? #2
Fred, you buying or selling? If you're buying, check the spindle bearings and each blade. That's where you're refurb expenses will be. That's a pretty good sized disc for a compact. Is it adjustable for gang angle?
If you're selling, I'll give you $50 for it /w3tcompact/icons/wink.gif
   / Used Disc; Worth? #3
That would go for around $100 at an auction, or less.
   / Used Disc; Worth? #4
I'd pay a $100 + for that setup. I would figure on putting in new bearings, if I was going to use it a lot. I'd like to find one in that shape. It looks a bit big (try it on your tractor, and sell it if it doesn't work out), but one could shorten the sections with a bit of work. From the picture, the individual blades look to be in pretty good shape, and that's a plus. Looks like a good find.
   / Used Disc; Worth? #5
I imagine that the TN70D won't have any trouble pulling it.
Chris
   / Used Disc; Worth?
guys,
I should have said right up front that what I know about these things would not fill a thimble.
I was thinking about buying, but have no idea what the value of such an old unit is.
The blades look pretty good, rusty but its mostly surface rust. What should I look for in the bearings?
Also no idea who manufactured this unit. How hard would it be to find parts?
I plan to pull it with a 4wd TN70 which is not really a true compact. I can't imagine that this thing is more than ~2000 lbs which should be with in the tractors capabilties.
Thanks for the advice.
Fred
   / Used Disc; Worth? #7
Oh geez Fred with that TN70 you could pull a disc three times that size!!
   / Used Disc; Worth?
Doc,
I thought that might be the case but it never hurts to be conservative.
John,
The new dics I have looked at are pretty light duty. The thing I like about these older units is that they are very heavily built.
Fred
   / Used Disc; Worth? #10
<font color=blue>...The thing I like about these older units is that they are very heavily built...</font color=blue>
I agree...!
Best bet is to pick up an older unit at an auction {square steel tubing frame}... so it will outlast the tractor using it... /w3tcompact/icons/blush.gif
{I only posted the "new" discs strictly for reference... against your posted angle iron pic...}/w3tcompact/icons/wink.gif
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
LINDE WELDER (A53843)
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A53843)
30 INCH TOOTHLESS...
1837 (A51248)
1837 (A51248)
