Used hydraulic fluid???
   / Used hydraulic fluid??? #1
kebo
Elite Member
Lexington, SC
2001 John Deere 790 4x4, bar tires
Are there any practical uses for used hydraulic fluid? Can it be used as bar lubricant on a chainsaw maybe? If not, any other potential uses?? This stuff is expensive and seems a shame to just pour it down the drain. If no ideas, I'll just head to the recycle center and dispose of it properly.
   / Used hydraulic fluid??? #2
I like to save what hydraulic oil I accumulate for my waste oil stove in the garage/shop for bitter cold winter weather. Helps used engine oil Flow better in the gravity feed system I have. It works good for bar/chain oil in the same weather for the same reason flows easier. Not so good in warmer weather though.:D
   / Used hydraulic fluid??? #3
Easy, weed stopper.:D
   / Used hydraulic fluid??? #4
I use it for bar lube. It runs out faster than regular chain bar oil but it gets used and rid of.
2008 D&P WELDING  18FT 2000 GAL FUEL TRAILER (A52472)
2008 D&P WELDING...
Horst Quick Tach Bucket (A52349)
Horst Quick Tach...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A52577)
2016 PETERBILT 579...
