Used tractor buying?
   / Used tractor buying? #1
smittyinsc
Bought a little over ten acres of land two years ago from Westvaco. It was cut and replanted with pine trees. It now has lots of underbrush and pines that are about 5-8 feet tall, and lots of deep ruts from the skid loaders. I want to clear the land and get it ready to build on; my question is (are) looking at a used tractor (30-40 hp) to do this with, 4 WD, and was wondering if this would be sufficient enough. My used question is, do tractors have an estimated amount of hours that they should have on any given year (cars they say 15,000 miles a year)? Just would like to get something to go by when I am looking. Thanks, smittyinsc.
   / Used tractor buying? #2
smittyinsc,
I'm not really sure I understand the question. 15,000miles per year for a car? Don't tell anyone, I must be abusing mine then, I've cut back to 30,000 per year /forums/images/graemlins/crazy.gif
The best estimate that I have heard is that you should expect about 5,000 hours on a well maintained tractor before a major overhaul. Some people manage to ruin their tractor in half that and some people manage to get double that out of their machine.
Good Luck,
Kevin
   / Used tractor buying? #3
Residential tractors often see very little use, you you may see a 10-year-old unit with 2-300 hours.
Farm and commercial tractors often have much higher usage, sometimes upwards of 1,000 hours per year.
A commercial units that was well cared for may be in good shape at 5,000 hours. A residential unit may have been seriously neglected and be badly damaged at 150 hours.
So you need to look carefully at what you're buying.
   / Used tractor buying? #4
I would look into hiring someone to clear the land since you not only have to cut the trees but also remove stumps and level and possibly add fill. Once that is done, you may be able to get by with a totally different tractor or get a smaller, newer model. Where are you in SC?
   / Used tractor buying? #5
SWB,
Good point. If I had that much land to clear I would hire a bulldozer for a few days or a week. It is the right tool for the job.
Good Luck,
Kevin
   / Used tractor buying? #6
An track hoe often does a better job with less soil disturbance when it comes to clearing land. With trees that small, a bigger tractor with a heavy duty brush cutter might be able to knock the trees down to size fairly easily. Or maybe even a chipper type device (they are built in Charleston and I think there is one in Blythewood).
What kind of time frame are you looking at in which to accomplish your project. The faster you want to do it, the bigger the machine needed.
   / Used tractor buying? #7
My neighbor takes care of his 6 acres with a 50HP (42HP PTO) New Holland 3010, 1996 vintage, that he picked up earlier this year for around $11K.
He bought a wicked John Deere 3pt soil ripper about 6 ft wide and cleared the brush from his parcel in less than a day. He didn't need a rotary cutter (brush hog) since there were no saplings on his place.
   / Used tractor buying? #8
30 to 40 HP, especially being 4WD would be more than adaquate for 10 acres. USed being a relative term, used HOW?
My father farmed over 300 acres with a 32 HP tractor. Never needed more. Today, HP equates to speed. speed = time. Time = money. People THINK they need mega-power tractors for small acreage.
I've seen 1 year old tractors with 2000 hours. I've seen 30 year old ones with 250. I've worked on tractors with 100 hours that were trashed. The 32 HP tractor that dad farmed with? It's 51 years old, has 17,000 hours, and is still working for a living. (With only minor repairs so far) Each tractor needs to be judged on a one-at-a-time basis.
The "standard" for farm tractors I've always gone by is 400 hours per year average. Seems to still work OK.
I'd rather buy a good USED tractor, and avoid the big price hit. THEN spend the difference on implements to make that tractor PRODUCTIVE.
JMHO---------------
   / Used tractor buying? #9
if you can find one. . Buying a used tractor is a good plan but patience is required . Good used tractors seem to be few and far between. I'm all for a used machine but gave up on a search because they were too far away, too many hours, to close to the price of a new one ect ect ect.
   / Used tractor buying? #10
keep in mind that the 51 yr old 32hp tractor mentioned early has little in common with a modern 32hp compact. Old tractors had big bore gas engines, with lots of torque; and the tractor had a lot of weight to get work done. Many of these new compacts are very light, and the hp is achieved at high rpm which doesnt deliver the torque. My 9n and a Massey diesel compact had the same hp on paper, but the 9n had twice the displacement and could pull way more in terms of plowing soil.
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2014 AMADAS SPC-6-36 LOT NUMBER 211 (A53084)
2014 AMADAS...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
UNUSED CFG INDUSTRIAL SSECAG-Y HYD AUGER (A51248)
UNUSED CFG...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51246)
2005 KOMATSU...
