Rake Using a rock rake for... Rocks!
   / Using a rock rake for... Rocks! #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
I have lotsa rocks. I tilled a plot and have lots on top and just below the dirt. Silly me, I thought that a rock rake would sift them out and leave the dirt behind. Instead, it just acts like a blade, pulling both. I tried removing every other tooth, and it was about the same.
The rocks are softball to melon sized sandstone. It is a basic King Kutter Landscape rake that I have borrowed...
Any pointers? Thanks!
   / Using a rock rake for... Rocks! #2
set it to harrow sideways
it will move the rocks into a long string,
keep moving that string until it gets too big, then pick up the rocks and move them with FEL and continue
   / Using a rock rake for... Rocks! #3
I have had the same thing happen to me before. If the soil is a little top damp it will tend to stick together. I was also trying to copmlete the whole task in one pass (impatient). After, I used the first pass to be moore agressive and pop them out of the ground. On the next pass, I angled the rake and set the 3pt so that I would only take a very shallow bite. This way I got mostly rock and only a little dirt. Hope that helps.
2014 UTILITY DRY VAN TRAILER (A51222)
2014 UTILITY DRY...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2014 GMC Sierra Crew Cab Pickup Truck (A50323)
2014 GMC Sierra...
Cat 315l Excavator (A50514)
Cat 315l Excavator...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2015 Mitsubishi Mirage Sedan (A50324)
2015 Mitsubishi...
