Value of a JD 317?
   / Value of a JD 317? #1
andrewj
Platinum Member
South Carolina
JD 5105
I found one for around 550. I will learn more aboutj it when I call the guy. What is the price range for a running unit with good sheet metal, decent paint? Thanks.
   / Value of a JD 317? #2
If it has the Series 1 Kohler, it's worth about the $550 he's asking. The early Series 1 had a bad lube design and if operated on slopes would starve for oil and self destruct. If it's a series II or Onan, then it's worth in decent condition, minimal rust, no leaks, no smoke, no bad noises, around $1000 or more including the mower deck. Worth more if equiped with the optional rear integral (sleeve) hitch, rear PTO, or any other attachments. This was the top of the 300 series in the late 1970's, but the early models suffered from engine problems as mentioned above. It's the last of the closed rear frame models and was replaced by the legenday 318, a total redesign. If you can furnish a serial number, I can give you more info, like year made and original engine installed.
2017 Dodge Charger Sedan (A59231)
2017 Dodge Charger...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2016 Cat TL1055D Telehandler (A56438)
2016 Cat TL1055D...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2013 Chevrolet Silverado 1500 Pickup Truck (A59230)
2013 Chevrolet...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
