Price Check Value of Satoh Bull S6300
   / Value of Satoh Bull S6300 #1
snakebitten
Lone Star State
JD 5525
Looking at purchasing a Satoh Bull S6300 4wd tractor with 1300 hours. It's not currently running and has been sitting for a year +. It comes with a Rhino brush hog. I would like to make a reasonable offer, but don't what to offer. All comments are appreciated! SB
   / Value of Satoh Bull S6300 #2
A older non-running off-brand tractor isn't worth much more than scrap unless you know positively what it needs (not what the seller tells you it needs)
What you got is a crapshoot.. you a gambling man?
   / Value of Satoh Bull S6300 #3
Agree. Literally offer almost nothing. Scrap man price and nothing more.
Thanks for all the advice and comments! I put a fresh battery in the tractor and it fired up on first crank with the old diesel fuel (engine sounded good too). 3pt lift, pto and trans work good. I will make offer this week. First need to make a shopping list of the first glance items noticed that need replaced. Thanks again! SB
   / Value of Satoh Bull S6300 #6
So, the seller now knows you fired up that tractor? hmmmmm I guess you needed to know, but now the seller does as well. It's a conundrum.
Nonetheless, as I understand from other comments, the parts are getting increasingly difficult to come by? Is that right? Is Satoh still in business? It was my impression that they have passed away.
   / Value of Satoh Bull S6300 #7
well I have the same tractor with 1425 hours on it, mostly stored inside, everything works and I have , Mott flail mower, Howard rototiller, post hole auger, front end loader, back blade and my favorite item, frame mounted backhoe. I have about 7500$ into all that and feel it is worth it, good little tractor and as long as you work within the limitations of its size/ class it gets the job done.
   / Value of Satoh Bull S6300 #8
Satoh was bought out by Mitsubishi. Some parts are obsolete, but you know there are obsolete parts on JD compacts too.
2006 HONDA RECON 250 FOUR WHEELER (A51243)
2006 HONDA RECON...
PTO Powered Generator (A50515)
PTO Powered...
2019 MDB FM180 FINISHING MOWER (A51243)
2019 MDB FM180...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2020 CATERPILLAR...
377811 (A48836)
377811 (A48836)
TAYLOR WAY (11) SHANK CHISEL PLOW (A51243)
TAYLOR WAY (11)...
