Value of used Kioti 60" Finish Mower
   / Value of used Kioti 60" Finish Mower #1
kiotilee
King George, Virginia
Kioti CK20 HST
I replaced my Kioti KRM03-60 Finish Mower with a ZTR last spring. I am interested in selling it and would like to know what it is worth. I have owned it since May '04 and have used it for approx. 50 Hours. It has been garaged kept, no dints or dings, little paint chipping. I would have to refill tires once a month during mowing season and greased all fittings at same time. I believe the belt is okay. I didn't notice during delivery but there was not much adjustment left to tighten belt then and now there is none. It wasn't slipping last time I used mower. I would look for shorter belt when replacing. Blades could be replaced if looking for excellent results. I have sharpened original ones quite a few times and they do okay job but I know better ones are available. Like I said earlier, it does not have solid tires so they usually have to be filled with air about once a month. Could someone please give me an idea what it is worth. Thanks.
   / Value of used Kioti 60" Finish Mower #2
I have a CK30 hst and was thinking of purchasing a 60 inch Kioti ref this spring. You can check my profile for my Email or reply to this post.I am in north eastern pa,:)
   / Value of used Kioti 60" Finish Mower #3
kiotilee said:
, it does not have solid tires so they usually have to be filled with air about once a month. Thanks.
Perfect use of foam.
worth about 50 % of new value if in decent condition.
Andy
   / Value of used Kioti 60" Finish Mower #4
It's a teaser, isn't it?
I'll go 30%
Jake
2012 VANGUARD 53FT DRY VAN TRAILER (A52141)
2012 VANGUARD 53FT...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52128)
2024 Ford F-350...
2015 CATERPILLAR 336FL EXCAVATOR (A51242)
2015 CATERPILLAR...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
2013 John Deere 310SK (A47384)
2013 John Deere...
Wolverine Quick Attach Skid Steer Rock Rake (A50514)
Wolverine Quick...
