Valve Clearance
   / Valve Clearance #1
thenorth
Markstay, Ont.
Foton 404
Hi there:
Can anyone tell me the valve clearance on my tractor?
It is a Foton 404, 40 hp, 3 cyl diesel.
thanks in advance guys
John
   / Valve Clearance #2
Please check the engine label and advise what it says. Depending upon the engine, they're typically located on the top of the valve cover, on the side of the valve cover, or on the side of the block (usually under the intake manifold).
//greg//
   / Valve Clearance
thanks greg;
it is a SL3105BT engine, i hope this helps..
john
   / Valve Clearance #4
No problem. Unfortunately I don't know that engine, so we'll have to hope someone pops by that's got the SL3105BT
//greg//
   / Valve Clearance #5
PM or Email Tommy at Affordable Tractors.
I believe he sells this model Foton.
He's a great dealer and I am sure he will help you if he can
   / Valve Clearance
I emailed to affordable tractors, alas, they do not know the required settings.............
   / Valve Clearance #7
If your engine runs in the upper (desirable) temp. range of 180°F to 195°F then .014" for intake and .016" for exhaust.
If your engine runs in the lower range of 140°F to 170°F then .012" for intake and .014" for exhaust.
   / Valve Clearance #8
   / Valve Clearance
Tommy:
I do apologise, I have the email you sent, I guess I got mixed up as I had sent a few queries to diff. people.
I thank you...
John
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
Genie GTH-844 (A50123)
2024 JOHN DEERE 331P-TIER SKID STEER (A51246)
2024 JOHN DEERE...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
1998 Blaw-Knox PF 150 Paver (A52384)
1998 Blaw-Knox PF...
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
