valve lock on 402 loader ?
/ valve lock on 402 loader ? #1
logan97
Blue Ridge Mnts, Va
Kubota B7800 4/wd
K B7800 402 Loader owners manual a little vague on the lock unlock position. Does it need to move when not in operation ?
/ valve lock on 402 loader ? #2
I assume you mean the small lever that can be positioned in the locked or unlocked position. I have owned my B7800 for 5 years and have never locked the loader controls. It would probably be important if you have children or remove the loader from the tractor(?)
/ valve lock on 402 loader ? #3
That lock does not move on it's own if that is what you are asking. It is locked when moved away from the tractor and prohibits the use of the loader. I used mine when the tractor was stationary and I had something hanging on the loader. I wanted no chance of bumping the loader control in any way.
2007 Rhodes AS3573 Trailer, VIN # 1A9AD35307P432073 (A64556)
2007 Rhodes AS3573...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A67148)
2016 FREIGHTLINER...
2015 International WorkStar 7500 29Yd. Side Loader Garbage Truck (A64194)
2015 International...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
2025 KENWORTH T880S DUMP TRUCK (A63276)
2025 KENWORTH...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
