Valve options for taking advantage of power beyond plumbing
   / Valve options for taking advantage of power beyond plumbing #11
Can anyone define "3 position" I think it means push-center-pull????
and also "4 way" does this refer to the number of connections? ie... one in , one return, 2 work ports?? Still trying to learn these hydraulic terms.
Thanks, Matt
I am lazy this morning so I will add a link rather than type;)
Hydraulic 4 way valve basics
The "3 position" simply means the handle can be in of three places-basically ON-OFF-ON
Mntview - Thank You for the tip on the cyclinder. Had not thought of that.
KennyD - Think "I" will follow your lead here...Thank You!
Dana
2010 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Sierra...
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
set of 4 sailun 11R24.5 tires (A56435)
set of 4 sailun...
2011 John Deere Gator Utility Cart (A55973)
2011 John Deere...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
