Vanguard in Cub problems
   / Vanguard in Cub problems #1
geneP
Platinum Member
Central Mississippi, USA
Case-International 385, Kubota L5450 w/LA1150A loader
I'm posting this in the Yard and Garden and Cub Cadet forums hoping someone out there is familiar with my problem. It started today as I was mowing the lawn trying to die when I turned right. straight ahead or turn left was ok. I finished the grass and took the side panels off to see if anything was rubbing the wiring or pinching the fuel supply. I moved a few wires around looking for loose connections, etc, but found nothing. I left the panels off and was going to run it around the yard to see if anyhting had changed. It would start and run about 2 seconds at high speed settings, and about 4 seconds at low speed settings. I thought it wasn't getting fuel, but the thing starts repeatedly after it dies. I put a screwdriver on a plug wire and it is firing while the engine decelerates after it quits running. It's a 16 HP VAnguard in a Cub Cadet 2165
Any ideas on what to look at would really be appreciated.
   / Vanguard in Cub problems #2
Hi! My opinion I think you have some water or dirt in bowl of carburator . You can drain bowl . tank may be add a new gas fiter with new gas. Good luck! Oldmech
Thanks Oldmech. I just posted on the Cub board that I found the problem . It seems as if the power wire to the fuel cut-off solenoid had a bad connection at the ignition switch blade. It would only get power while in the start position. Unless the switch itself is going out, the problem has gone away.
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
2016 Ford Taurus AWD Sedan (A50324)
2016 Ford Taurus...
2005 KUBOTA KX71-3 EXCAVATOR (A51242)
2005 KUBOTA KX71-3...
2013 John Deere 2210 Accudepth Field Cultivator (A52349)
2013 John Deere...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
