Ventrac Block Heater
   / Ventrac Block Heater #1
Near Cobourg, Ontario
TN75DA
Hi
We live in southern Ontario, near Cobourg. We just purchased a used Ventrac 4200, 31 h.p. gas engine. It would not start on the first really cold day (minus 2 deg F; minus 14 deg C).
Does anyone here know about block heaters for 31 hp gas Ventracs; like whether there is a port on the block, where it is, what spec for the heater etc? Also, would anyone recommend a heated battery blanket?
Thanks folx
HPD
   / Ventrac Block Heater #2
I have an older Kubota B7100. There is no provision on the engine to install a block heater.
I found a block heater that fits into the lower radiator hose. All you do is cut out a piece of the hose ,and install it with hose clamps. Works great ,and I think it came from NAPA.30-40 minutes is all that is required in -20 C weather,and it should fire rightup.
Good luck Pacific pete
LS Mtron XG3140 MFWD Compact Tractor (A49339)
LS Mtron XG3140...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A46683)
2018 Bobcat T590...
Front Weight Bracket (A49339)
Front Weight...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A45336)
2020 Ram 1500 4x4...
2017 John Deere 410L Loader Backhoe (A46683)
2017 John Deere...
3103 (A46502)
3103 (A46502)
