Ventrac Question
   / Ventrac Question #1
heliman
Southwest Lousiana
Ventrac 4231TD & Kubota L47
I have been looking at the Ventrac 4000 series for a couple of months now and am hoping I can get some expert advice from the group. BTW, I have enjoyed reading the different post on the site and appreciate any feedback.
A couple of years ago we moved to a new house with approx. 4.25 acres and several hills. The slope gauge on my Toyota FJ showed 35 degrees on the steepest hill with most of the hills being at 30 degrees. (I hope I got the degree vs. grade thing correct. I am still new at this). I have tried to get several mowing services to come out and all but one have taken one look at it and run the other way. The one that tried it with a ZTR mower went up half way on one of the lesser hills and then apologized for taking the job and left. In addition to mowing, I don't think I can go through another winter like last year without getting something to handle the snow. We are approx. a half mile off the state maintained road with part of it being gravel and the other half paved.
Again, I appreciate any feedback on the following questions:
Does anyone know why Ventrac has discontinued the 4231 Vanguard 31 hp Liquid Cooled Gas engine model? If I was to purchase one what are the risk?
What are the benefits / risk of getting the 4131 Vanguard Air Cooled Gas model with the 4100 Accessory kit versus the 4231TD Vanguard Liquid Cooled Diesel model? From what I can deduce, I may not have a choice given the hills and the 4231TD痴 oil system.
What are the tradeoffs between the slip scoop and the excavator bucket? Not sure I have a planned need for either, but think it would be nice to level out a section near the top of the mountain and move dirt to the garden and spots in the yard.
I really appreciate everyone痴 feedback and patience.
   / Ventrac Question #2
Hi,
I have had a Ventrac since 2004 -- Using the 4231 Gas with duals I can easily mow the back side of my pond dam and I have measured it at 39 degrees in some places. I go up and down as opposed to across using the backrest for support.
I loved my first Ventrac 4231 Gas so much that I recently traded it in on a new one. Ventrac (unlike some companies) has made some changes and ALL that I have seen are for the better (either stronger, easier, or more responsive)
I understand that now (unless you find one that is already made or is used) the 31 Hp Gas model will not be available because of stupid EPA rules.
I would not hesitate to buy a Ventrac and there are many attachments that make it a very versitile machine.
Try to contact them for a demo. The web site has a dealer locator.
   / Ventrac Question #3
Ventrac 4000 series tractors with DUAL WHEELS are capable of operating on slopes not exceeding 30 degrees. For steep slope operations, Ventrac has specific engine requirements. If you are only INTERMITTENTLY on slopes of up to 30 degrees but more than 25 degrees, any available engine provided by Ventrac for 4000 series tractors will work fine. If you need to be able to operate CONTINUOUSLY on slopes exceeding 25 degrees but no more than 30 degrees a Diesel engine is required. These engines have had special adaptations made to prevent oil starvation for continuous steep slope operations. The 31 hp gasoline engines are, therefore, not suitable for CONTINUOUS 30 degree operations. The line is not clearly drawn in distinguishing Continuous vs. Intermittent, but by viewing some of the Slope videos on the Ventrac website Ventrac Compact Tractors & Attachments you can get an idea of how they are being used. For example, see the video clips of me mowing on a 25 degree levee in Ohio and of Jeff Hostettler at his horse farm/estate in West Virginia.
I have owned 4231 tractors with the Vanguard Liquid Cooled 31 Turbo Diesel and the 31 hp Gasoline engine. Performance is basically indistinguishable between the two, but, as noted, the Gasoline versionis no longer available. (There is a Gasoline version now offered on EBay.) I don't have any experience with the 31 hp air cooled version, but with the Accessory Kit, the features are the same as the 4200s. You absolutely must have the Weight Transfer system and a full set of rear weights on a 4100 to be able to operate on hills. These are standard on 4200 models.
The Slip Scoop is great for scooping up and moving loose materials. If you need to actually DIG into firm soil, the Excavator scoop is better.
Since you have both paved and gravel roadways, the V-Blade is probably your best choice for clearing snow. The Snow Blower is outstanding on paved surfaces.
   / Ventrac Question #4
The gas model is cheaper than the diesel, and it runs on gas. Supposedly the EPA is making a mess with small motor regulations, and this is probably why certain engines are being discontinued. I recdently traded my 4231 gas for a Turbo Diesel model. It doesn't really have much more power, but it runs better, gets far better gas mileage, and just generally seems to be smoother. The diesels are rated for continuous operation on 30 degree slopes. They can handle a bit more intermittently, but that is their rating. I mow 30 degree slopes with the 84" contour mower, and it is no problem.
For slope operation, you definitely need the dual wheels, and the weight transfer springs.
A ZTR mower doesn't have a chance on slopes like that.
   / Ventrac Question
Thanks for the feedback. I have a demo scheduled for next Friday.
In addition to talking about the tractors, the sales guy and I spent a little time talking through mowers and dozer blades and wanted to get y'alls thoughts.
My previous thinking was to get the offset 72" side discharge deck, but the sales guy brought up the fact that the offset deck will pull you to the side when going up the hills; thus, making it a little harder to track straight, and in my current place I really don't have a need for the offset.
As a result, I am torn between the 60" side discharge and the 72" side discharge. Are there any issues if you use the 60" deck when the footprint of the ventrac with duals is 70"? Is it just a productivity thing? Will this affect the Ventrac's striping ability?
Additionally what are y'alls thoughts on getting the poly edge on the dozer blade?
Thanks again for all the help.
   / Ventrac Question #6
You can get away with a 60 inch deck with the 70" duals if you always mow short, but the standard 72 inch deck will give you much better results for all sizes of grass.
When considering blades, if your primary application is snow removal the V-Blade is outstanding. Poly blades are used to minimize scratching on asphalt, so if all of your blading will be on well-maintained asphalt then they are a good investment.
   / Ventrac Question #7
I would go with the 72" deck (that is what I have with the Duals), but the 60" would do just fine. I actually tried out the 60" deck with the duals and I think I remembered it cutting fine, but the annoyance was trying to figure out exactly where my last mowing pass ended since there was a small strip of grass that was pressed down by the extra length of the duals. You would probably get used to it, but as far as striping or mowing I wouldn't see it being a problem with the 60", maybe just a slightly lighter press on the outside of your line? Don't know just a guess.
As far as poly edge, they are perfect if you are moving snow on cement. Perfect finish and no scratches on nicer cement driveways. If you want to dig in the dirt, I would suggest sticking with the hardened edge. But for snow, the poly edge is a great choice!
   / Ventrac Question #8
I think the contour deck is the ultimate mowing machine. I also have the 72" deck, but rarely use it. I can't imagine dropping down to a 60". It will be difficult to cut up against obstructions, such as trees, flower beds, etc. Your weed wacker will have to work overtime.
   / Ventrac Question
I appreciate everyone's help with this. I was extremely impressed with both the machine and my local dealer. He truly wanted to make sure we got the right solution even if that reduce the overall cost. A trait that is becoming very rare these days.
My new 4231TD ventrac was delivered yesterday morning!!! During mowing of the back yard, I pushed it a little harder than the demo unit and am amazed at this machine. At one point I felt like I could just lean forward a tad and I would have been standing straight up on the pegs. I now know why everyone was talking about armrest on another thread. I think that's going to be a purchase in the near future.
Again, I appreciate the advice and am sure I'm going to need more as I near the maintenance schedules.
Thanks,
   / Ventrac Question #10
I'm sure you will be happy with your new Ventrac ! :thumbsup:
I didn't see where you live, but if you get a great deal of snow the Ventrac will also handle the blower just fine on gravel if you keep the skids as low as they will go and Keep most of the weight off the blower with the hydro lift.
I did 9 long gravel drives and over 1/2 mile of gravel road with my blower when we had 20+" and then 24+" snows.
I got the regular 60" blade before the V-blade was available and it is fine if you have a place to push the snow.
V-bar chains make the Ventrac nearly impossible to stop and it has amazed people with what it will pull when they were stuck.
Have fun with your machine ! :thumbsup: :D :thumbsup:
   / Ventrac Question
BK, I am just south of you in the Roanoke/Salem area. For once I am hoping for snow :cool:
BTW, is there any trick to connecting the hydraulics on the slip scope? One hose goes on and off very easily, but the other one just will not allow the clamp to close down.
   / Ventrac Question #12
The reason the 2nd hose won't connect is because there is still pressure in the line. You can push on the center pin in the fitting on the hose (there is pressure in there so hydro fluid will come out under pressure) I usually use the space where the front fender comes together with the tractor body so oil won't hit you. To avoid the situation - before disconnecting the hoses - turn engine off and move the bucket tilt lever side to side a few times to release the pressure on both hoses. :thumbsup:
BTW, is there any trick to connecting the hydraulics on the slip scoop? One hose goes on and off very easily, but the other one just will not allow the clamp to close down.
   / Ventrac Question
BKBrown,
Thank you! Thank you! That worked and was a lot simpler than I was expecting from the operational video. Just a little hydro fluid came out and then snapped on with little effort.
So with this tip I was able to use the slip scope for the first time this weekend. When I started looking at the Ventracs I didn't have a clear need for the slope scope, but knew opportunity would be knocking. We are hopefully having a new water well put in this week and had a tree that had fallen down on the well road. Having the slip scope was a big time saver. Not only was it able to move the cut up pieces of wood but allowed me to move two big rocks that I never would have gotten by myself. It was a great time and gave me some good times with my son. On a side note, I was proud of my eight year son this weekend. Since I was on the Ventrac driving the logs up the road and he was doing the loading, I kept asking him if he needed a break. After the second time of asking him, he replied "Dad, I don't want a break. I want to focus on getting this done so we can go on to the next item on the list." Simple things that bring a smile to your face.
Now I'm off to start working on the plans for a fire pit :)
Thanks again for the help.
   / Ventrac Question #14
No Problem :thumbsup: -- Simple fix :D -- remember to release pressure before disconnecting those lines. If you got the 3-N-1 you can also use the scoop on the back, but you'll want some weight on the front.
   / Ventrac Question #15
I am a Steiner owner, not Ventrac but wanted to post this just so you will know...This is from my Steiner 525 manual.
It isn't because the machine won't do it, there are other things that control the max slopes your machine will handle for reasons listed. Sorry about the sideways picture, but it allowed me to get the whole page part I wanted you to read.
David from jax
   / Ventrac Question #16
Thanks sandman,
Does your Steiner have the same Briggs/Daihatsu engine that our 31 Hp Gas and Turbo Diesel have ?
Is your Steiner from before the Steiners sold to another company ?
Have you seen the Ventrac to compare ?
Questions, Questions ???
   / Ventrac Question #17
Mine is a 1996 Steiner 525 bought used by a friend who went to an auction with a pocketfull of my cash. I sent him after a tractor, and 15 minutes later the auction ended. I asked him "via phone" if we got a tractor and he said no, but we did get a lawnmower.
He said it was listed as a "non running" item and he paid $503 for it. Me, thinking Craftsman lawnmower, said you paid $503 for a non running lawnmower? He said, yeah, but it is hydrostatic drive. (but it doesn't run!). He said it was 4 wheel drive (but it doesn't run!). He said it had a Kubota diesel engine (but it doesn't run!). He said it has an extra deck AND a leaf blower! (but it doesn't run!). He said "I can get it running!
I grabbed a trailer and went to pick it up, and he was out driving around on it when I got there. He was right, he got it running, as somebody had just left the key on and drained the battery. I went by his house the next day to pick up the manuals and he told me it was a shame I didn't have an extra $500 at the auction. Seems everyone that wanted a tractor got one, but one JD2555 didn't sell because it didn't make reserve. (reserve was trade in value by a local company) I asked him if it could still be bought and Monday he checked, and I became the proud owner of a JD2555 which is how i ended up on Tractorbynet.
The Kubota diesel engines have increased in horsepower over the years. I think mine is listed at 23.5hp. I have two of the 60" decks of the newer style and a pto blower. I later purchased a pto 10KW generator that was built exactly like the 10KW generator that Steiner offers, just without the pricetag.
From what I see on ebay, I could probably recoup my money just by selling one of the decks, but with 5 years of mowing under my ownership, it doesn't owe me anything!
David from jax
   / Ventrac Question #18
Very nice!! :thumbsup: Glad to see another happy Ventrac owner, our kind are growing quickly in number :laughing:
Edit: @ sandman
That slope chart for the 525 does not apply for the Diesel Ventracs (Call B&S if you don't believe me :D). The engine itself is rated for CONTINUOUS 30 degree operation, 35 degree intermittent. I believe the Gas Ventracs (like mine) technically are rated at 25 continuous and 30 intermittent like that chart, but I run mine for hours on a 30 degree slope with no problems. My dealer said that they have never had any problems with any of the engines not handling 30 degrees continuous on the Ventrac. So the diesels are perfectly capable of continuous 30 degree operation. Manufacturers have to put some number down to cover their butt. I am sure that the diesels would have no problem at 35 degrees continuous.
   / Ventrac Question #19
The 525 that that manual came with is diesel, and what would B&S know about diesels???
Did you see that 35 degree continous rating in print? I would be interested in seeing it, because if you believe a salesman is going to tell you the truth about it...well, you will be surprised. The texts aludes to the reasons for the rating, and I don't think it has anything to do with what fuel it is running. In fact, two of the three reasons given would make me NOT want to use a diesel engine on the steeper hills, as they are coolant and lubricant sensitive, more so than a gas engine, or at least more expensive to fix when one of those reasons takes over.
I don't have to worry about it, as my yard is FLAT. I just posted it so the O/p would realize it was just a little beyond STEINERS ratings, and since they are similar machines it would stand to reason the ratings should be close.
If I needed to to a yard with a hill in excess of the ratings, I would tend to want to climb it on the easiest point and go downhill for the actual mowing, then catch a little time mowing a flat area, then do another strip on the hill. That would make it the easiest on the machine, and since they don't give them away, making it last is a good idea.
David from jax
   / Ventrac Question #20
If you need to go really steep, Power Trac has one rated for 45 degrees, their PT1850.
Ken
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2005 Sterling Acterra Tender Truck (A56438)
2005 Sterling...
2017 Ram 5500 Bucket Truck (A56438)
2017 Ram 5500...
