Very close 3ph chains- adjust rear wheels?
   / Very close 3ph chains- adjust rear wheels? #1
DiskDoctr
Platinum Member
Western PA
Mahindra 3510
When using 3ph items (tiller and mower so far), I find that there is only about 1" clearance between the chains and the inside of the tires. It seems clear that they rub when not on level, especially the handles on the turnbuckles.
I saw something in the manual about being able to adjust the rear wheels for a wider stance. Not sure if this will make a problem on the trailer, though. It is 6' inside, wheels are now 64" outside.
Has anyone made this adjustment, and what has been your experience? Any problems or tips?
Thanks.
-JC
   / Very close 3ph chains- adjust rear wheels? #2
Looks like people are a little slow to respond to your post. I can't really help much but your book should outline different spacing. If not then just take a look around at the rims, etc. I know on my Zetor all I have to do is swap the wheel from side to side and would gain a few extra inches. Maybe measure the offset of the rim from both sides then times 2 and that should be how many inches you would gain (or lose) by swapping sides.
Hope that helped
2014 JOHN DEERE 4066R LOT NUMBER 23 (A53084)
2014 JOHN DEERE...
3 Point 5 1/2ft Metal Screen Cargo Carry (A51573)
3 Point 5 1/2ft...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
