Vickers V210 vane pump - which filter to use?
   / Vickers V210 vane pump - which filter to use? #1
avz
I'm trying to assemble a small power pack with an old Vickers V210 vane pump. I understand that there are two types of filters, an intake suction immersed filter or a return line filter. as per your expertise, could you advise me which type is adequate? I'll appreciate a short explanation, too.
   / Vickers V210 vane pump - which filter to use? #2
If you can get all the returns from that system to return back to the same place, get a return filter and a strainer for the suction side of the pump. The filter will get almost everything before it gets to the tank and contaminates the rest of the system. The strainer will prevent possible big chunks from getting pulled by the pump.
If your system is like a tractor, where the returns don't go all to the same place which makes it hard to have a return filter that can catch all the return, you'll need a filter on the suction side of the pump.
First option is usually the best too.
2000 Genie S-60 60ft Telescoping Boom Lift (A50322)
2000 Genie S-60...
Richie Water Master 1200 Trough (A50774)
Richie Water...
2015 Cadillac Escalade ESV Platinum AWD SUV (A50324)
2015 Cadillac...
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
