Voltage regulator?
   / Voltage regulator? #1
bmartin172
Flintstone, MD
2019 Mahindra 4540 and 1986 Ford 2110
1986 Ford 2110. Head lights, fuel level and temp gauge all stopped working suddenly. Any ideas? Voltage regulator?
   / Voltage regulator? #2
What voltage do you get with tractor off and how does that compare with tractor on? do you get any voltage on temp sender? did you check fuses any? as the name implies voltage regulator work along with the alternator to " regulate" good charging voltage. That should not directly effect gauges. need to dig in more.
JC,
   / Voltage regulator? #3
If the tractor starts and runs normally I would look for a main fuse or possibly a defective ignition switch. Of course if it's not charging the battery will eventually go dead from starting the tractor.
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
(4) 12' & 10' Pipe Gates (A50515)
(4) 12' & 10' Pipe...
PALLET OF CIRCUIT BREAKERS & MISC PIPE (A51244)
PALLET OF CIRCUIT...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52128)
Texas Post Driver...
Quick Attach Pallet Forks (A47384)
Quick Attach...
Agco 8200 Flex Grain Platform (A50514)
Agco 8200 Flex...
