Voltage Regulator
   / Voltage Regulator #1
frank77367
East Texas
1987 Yanmar YM-220
I have a yanmar YM-220, the charging light is staying on, it has the little 2 wire alt. how can I check to see if the reg. is working , can any of the parts stores like napa check this, if I take it off?
Thanks so much
Frank
   / Voltage Regulator #2
I would think any parts store can check that alternator, and if it's putting out correctly, you'll probably need a regulator. Check that all the ground connections are good first tho........
   / Voltage Regulator #3
Disconnect 2 alternator wires . Connect alternator wires to AC voltmeter. Run tractor at about full throttle. Output should be 20-30 volts AC. Don't run any longer than neccesary as damage may occur. If alternator is putting out sufficient voltage , regulator is probably bad.
76in Smooth Bucket with Hydraulic Swivel Attached (A51573)
76in Smooth Bucket...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
20" Sea Container (A47384)
20" Sea Container...
2021 John Deere 331G Track Loader (A53342)
2021 John Deere...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2008 Ford F350 XL, Diesel Dump Bed w/Spreader Box (A52384)
2008 Ford F350 XL...
