Warne scope base question - Difference between M898828 and M898829 ?
   / Warne scope base question - Difference between M898828 and M898829 ? #1
Big Wave D
Platinum Member
Kubota L35, Kubota B6200E
Thanks to all who might look and respond to my question,
I have a Smith and Wesson, Model C Rifle in .30-06 w/HVA 1900 action -- I bought it years ago for a Western hunt that never came to be. Fast forward to today, I now have a hunting use I want to press this rifle into service for and would like it to be scoped.
So, I'm wanting to purchase scope, rings, and bases through Amazon to take advantage of the no interest if paid off within the special financing period. That being said, I can't seem to find the correct base set on Amazon that I want, in Matte finish.
Based on Warne's lookup page from their website, it says that I'm in need of the combination: M898828M (for Matte black) - M898/828M - Warne Scope Mounts
When searching on Amazon, this is how Amazon describes them,
Mauser 96 Small Ring Mat 2Pc Base by Warne
My problem is this. I can't find that exact part number on Amazon. I DO find: M898829M - which should be Matte finish (but pics Amazon shows look more like stainless to me)
I have several questions:
  1. Does anyone have some kind of link or actual literature that gives actual specifications to a given part #?
  2. Can those two sets be used interchangeably, being only 1 digit apart on the last number?
  3. Do the numbers represent the thickness/height of each base piece?
  4. If the pictures is right and they are silver in color, what method would you use to make them into a black, matte finish?
  5. Total flyer, anyone shooting with a Vortex scope? (Looking at Diamondback or D-back/HP -- Love some feedback. I've read a lot on them, and they seem to have quite a bit of positive feedback.)
Again, thanks to all for your help... :thumbsup:
   / Warne scope base question - Difference between M898828 and M898829 ? #2
M898/828 - Warne Scope Mounts
Maxima M898/828 Fits Mauser Small Ring 96 Altered
This probably means with the clip slot hump removed. This would also apply to a commercial receiver made to the same dimensions, without ever having a clip slot.
M898/829 - Warne Scope Mounts
Maxima M898/829 Fits Mauser Small Ring 96 Unaltered
This probably means with the clip slot hump intact. It has a relief cut in the bottom front of the rear base. Doesn't show in the Warne photo. Could be used on an altered rifle but would leave a gap under the front edge.
Better photo:
Warne Maxima 2-Piece Steel Weaver-Style Scope Base Swedish Mauser 96
Bruce
bcp,
Thanks for helping to clear up my confusion over the part #'s for me.
You are correct. My action would be considered 'Altered' due to the lack of the clip slot. I had to do some searching to find out exactly what that meant. Once I'd found that out, I was curious how it was used. YouTube helped out on that one. Scoping a rifle with that feature kind of negates its handiness, if so equipped - I digress.
Anyway, since it only seems to be a cosmetic issue for me, I think I'm going to go ahead and pull the trigger on a 'clip' version of the Warne scope bases. If I decide I really don't like the aesthetics, I can always find the correct bases locally.
BCP, once again - thanks for clearing up that matter for me.
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2012 CATERPILLAR 259B3 SKID STEER (A51242)
2012 CATERPILLAR...
RIMS AND TIRES (A50854)
RIMS AND TIRES...
1984 Ford F-Series Flatbed Truck - Classic Workhorse Selling Absolute (A51039)
1984 Ford F-Series...
