Water Decision
   / Water Decision #1
Alan L.
Elite Member
Grayson County, TX
Kubota B2710
Well its nut cuttin' time on my water. I finally got the bid from the Rural Water system for connecting. It is a mere $10,250 (after I talked them down by $575).
I've talked to 4 water well drillers. Basically the price per foot is the same but they are telling me all kinds of different stuff as to why a particular depth is better.
In our area there are two aquifers - the Woodbine and below that, the Trinity. Driller number 1 says drill 1000' to the Trinity for $20,000. Driller number 2 says drill 400 - 600 feet to the bottom part of the Woodbine for about $10,000 - $14,000. Driller #3 and #4 both say drill to the top part of the Woodbine - about 260 - 320' for $6,500.
So now I have to decide not only whether to go with a well vs the rural water system, but which depth? My reading about the Woodbine aquifer says there are three layers and the top one has poor water quality, so I think that rules out drillers #3 and #4 as they told me the water quality was the same regardless of the depth in the Woodbine.
Driller #1 is pretty much out as too expensive. That leaves driller #2 who drills to the bottom of the Woodbine. He admits there can be some iron and sulpher problems, but says in my area in the lower part the iron content has been negligible and most of the sulpher can be taken out before it gets to the house just by exposing the water to oxygen in an open system (galvanized tank vs bladder tank). According to my reading the Woodbine tends to have a fairly high iron content, though not nearly as much in the lower levels.
If I go with the water system I will be paying water bills of up to $100 and even more in the summer. The 19,000 gallons of water I used last July would cost $85. With the well its about $1,500 if the pump goes out, plus you do with out water until it is fixed.
Driller #2 drilled a well into the lower Woodbine - about 500' on an adjoining tract a couple years ago. I collected a water sample there this morning (nobody home, so I ran water into a jar out of the outside faucet). The water looks and tastes very good. Maybe better than the city (Trinity) well water I'm drinking in town now. Of course you can't see all the stuff that could be in there that is harmful.
With the water system they are regulated and have to do whatever treatment is necessary to keep the water healthy. If I have my own well I'm on my on.
I'm leaning toward driller #2, but I would appreciate any experiences or other input on the subject.
   / Water Decision #2
Around here, most well companies are willing to offer an 'easy drill' price. That means, the price is low if they don't hit a rock. If they do, then it's the standard price. You'd think a company would tell customers about easy drill prices to get a job, but maybe not. It's probably worth asking.
   / Water Decision #3
You will get more information if you tell people where you are located. I am familiar with wells in North Central Texas and into the Central Texas area.
First, well drillers are just well drillers. They can only tell you how they drill the hole, the way the protect the casing with gravel pack and cement the well. They don't make water, purify water, understand where the water even comes from, or really care. They normally charge by the foot and you pay whether or not they ever hit water that is acceptable to you. The pump is also just that, you can specify what you want, but the cost is primarily decided by the depth of the well and the amount of water available to pump.
Unfortunately it is not rocket science either, but most long term well drillers know what to expect 90% of the time. I have water with no iron, and people two lots away have lots of iron. Water treatment can be easy or expensive depending on what you have to deal with. Rules for placement of a well (legal requirements) must be met to try to keep sewage out of the well. You never know when someone is putting sewage down a well because their septic tank doesn't work! That is why they make you test it before it is used.
Small amounts of iron are treatable easily with a water softner. Small amounts of sulfur (smells like rotten eggs) are treatable on a continuting basis by adding a 1/2 cup of Chlorine mixed in 5 gallons of water to the well about once a month. It won't hurt you, it just smells bad.
Wells here drilled by reputable low cost drillers for homesites run about $2400 for a 200 ft well with pump and 80 gallon bladder storage tank. In this area, there is little to be gained by going to the lower aquafier. In other areas of Texas, most of the water comes from about 450 ft and costs about $5400 for a complete system.
My well in California was over 600 feet deep drilled through solid granite and only put out a minimal amount of 3 or so gallons per minute. Water is relatively cheap to drill in a lot of Texas and there are hugh amounts of water available.
There are risks to drilling wells. A friend of mine (who is a lawyer) had a well drilled, it worked just fine for a couple of weeks, the ground shifted and he had the same expense to drill another one 10 feet away. There are no guarantees on wells. If someone does guarantee them, then they are charging enough to be sure they don't lose money drilling for you. Many drillers will travel 100 miles to drill a well, so check outside of your area for someone who will do it on a per foot basis, then check others in your local area to see what you want to drill in terms of depth. Most drillers will tell you the truth as well as they know it, but every well is somewhat unique.
   / Water Decision #4
I personally would prefer my own well over any rural water system. Some areas will not let you drill a well if a co-op system is available to you.
   / Water Decision #5
Alan, have the drillers said anything about the possibility of not even finding water. I understand they will find water, of varying degrees of quality, like Wen said, in most places; however, I know of one guy in my area who paid for drilling 4 dry holes before he gave up (I don't know just how deep they went though).
Bird
   / Water Decision
My area is north central Texas, north of Dallas about 50 miles. All the drillers say there is a 99.9% chance of getting plenty of water, but the don't guarantee it of course. The question of whether or not you will get the amount and quality of water is one reason for considering the municipal water. Well, I'm off to meet the driller at my place and talk it over!!!
   / Water Decision #7
I wouldn't count on that...maybe they are *supposed* to, but it doesn't mean they are...I have my own well, and luckily the water tastes better than the best bottled stuff money can buy.
I have read more than one article in the past few months where the people running municipal water systems have really screwed things up...somewhere down south (Lousiana maybe?) they Dept of Public Works hooked up a sewer line to the water system and made a lot of people very sick (and a lot of lawyers happy)...the residents were complaining for weeks about bad tasting water and little bits of paper in coming out of the tap, and they were told there was nothing wrong...can you imagine anything more disgusting than that? In the town next to me (the one I used to live in) I had "town" water and it was so terrible we only drank bottled water (population was under 2000, so it was a small town). they were routinely cited for having unacceptable levels of contaminants in the water....I could go on and on...
I've had pumps now for over 6 years, not had one go bad yet. I am sure they do, but its not all that common. Its not like you will be replacing them every few years...my recommendation would be that if you can get good water on your own property, go for it.
   / Water Decision #8
I thought it was California that was recycling sewage to drinking water! /w3tcompact/icons/laugh.gif
Guess that is why they make us keep our well and septic lines 75 ft apart. Hard to get them connected that way. /w3tcompact/icons/smile.gif
Unfortunately there always exists a health hazzard with any drinking water, well or municipality.
When we tested all waste water for all heavy metals, they would fine us for discharging the same amount of heavy metals that was present in the municipal water they were selling us! Don't count on municipal water being fit to drink.
   / Water Decision #9
Alan,
Maybe you need to find some less expensive well drillers. Too much prosperity in North Dallas.
   / Water Decision #10
Yep, there are some hazards in any of the water systems; especially in Texas. I learned that the Texas Natural Resources Conservation Commission (TNRCC) is a paper tiger. For two years, I was on the board of directors for our water system, and the TNRCC told us a lot of things we were "required" to do to upgrade the system, and we agreed. Of course, the only way to pay for those improvements was to raise the water rates, which resulted in petitions to throw out the entire board of directors, a frivilous lawsuit that was eventually dropped, accusations of having too many employees, making illegal purchases (which never happened of course), accusations that the board president was stealing (I was vice president and would personally have seen that he went to jail if there'd been any evidence of that), etc. Well, then the TNRCC refused to get involved, we got a whole new board of directors who rolled the rates back - for 9 months; most of the new directors resigned in less than that 9 months when they realized what they had gotten into, then they really jumped the rates up higher than ever, and now 2 years later, they have twice as many employees, nothing has been upgraded, but they think they are going to start upgrading sometime soon.
Bird
   / Water Decision #11
I heard about the Louisiana thing as well. Here in Ontario, Canada, we've recently had around a dozen people die in a town of 5,000 and over half the residents seriously ill. The problem was e-coli contamination in a well-fed system. The suspected cause was heavy rains, which flooded wells with surface runoff water from cattle operations in the area. Unlike the Florida case, some of the purification equipment didn't seem to be functioning.
The provincial government finally agreed to launch a public inquiry over the issue. The inquiry will have to sort out whether a decade of government cutbacks and privatization of public utilities contributed to the tragedy. However, for us, I've got to be happy with our wells since there are no rural water systems in the area.
   / Water Decision #12
Alan, have you reached any conclusions or made a decision yet about your water? I'm curious about what a well costs, how deep you have to go, quality of water you get, etc. if you go with a well instead of the community water.
Our water company notified us yesterday evening that our supplier (City of Corsicana) was going to shut off the water at 4 a.m. this morning for 24 hours to repair a main. The community water system's tanks may (or may not) have enough to last until it's turned back on again.
Bird
   / Water Decision
I now have a 500' water well. Unfortunately I don't have any electricity yet, so I can't pump the water out. The driller pumped it out some with a generator and says it will produce about 30 gpm. They put a 5 HP pump on it, which they wouldn't do if it wasn't a good producer. I'm real happy about that. The driller also said he thinks the water is soft, as he said it still had not cleared up while he was pumping it (I hope it clears up). I really won't know the quality until I can get power, but he thinks it will be real good. The cost should be about $12,000 although I haven't received the bill.
With the rural water I found they were hooking my 4" line to a 1.5" line. That pretty much decided it for me.
   / Water Decision #14
Your "4 inch line"? What in the world are you doing (or going to do)? Most of the folks around here have a 3/4" line from their meter. Our rural water system was just started in 1970 and in a number of cases, a 1" line was run long distances (at a considerable cost to the customer). Then in later years, additional new customers tied onto that same line, and now a lot of folks hardly have enough water pressure to take a shower. Even though the TNRCC says you have to maintain 20 psi in the lines, it frequently isn't done. I'm lucky enough to be on a two inch line at a lower elevation than the pump station, so I have 80+ psi all the time. But I'm glad to hear you got a good well, even though you had to go pretty deep, and at a considerable cost.
Bird
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2021 FREIGHTLINER...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
2014 Ford Fusion Passenger Car, 2.5L Engine - Only 90,875 Miles (A56438)
2014 Ford Fusion...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
