Water in fuel causes $10,000 damage to my Kubota Grand L6060
   / Water in fuel causes $10,000 damage to my Kubota Grand L6060 #1
Complete Turf Care
Veteran Member
South Louisiana
2022 Kubota Grand L6060 (no loader), 2017 Kubota Grand L6060, 2011 Kubota L5740 HSTC-3, 1997 Kubota M4700
Like the title says, water in fuel caused me a $10,000 repair bill to my 2017 Grand L6060 with about 1200 hours on it. The water caused rust in the fuel rail which caused damage to the injectors. I have had fuel problems with this tractor since its new.
I have a 100 gal. nurse tank that I use to fuel my tractors. I assume that condensation is happening in this tank. I do add a fuel 'cleaner' to each 100 gallons I put in the nurse tank. I guess this is mostly my fault, because I don't monitor the water separator on the tractor closely enough. I will check it more often now after this.
   / Water in fuel causes $10,000 damage to my Kubota Grand L6060 #4
Wow. Sorry this happened; that's an expensive lesson.
When storing fuel in your own 100gal (or whatever size) tank, I would install a fuel/water filter/separator right at the tank. Everything being pumped out of that tank would be filtered, and with the sight glass on the tank filter, you will see at a glance, the condition of the fuel you are pumping.
Racor would be my first choice, but there others that would be fine. Also, a routine of regular inspection and replacement of tractor fuel filters always best.
   / Water in fuel causes $10,000 damage to my Kubota Grand L6060 #5
People roll the dice using slip tanks for their common rail diesels. High pressure fuel pumps hate water.
I agree in putting in a racor water separator on the tractor and a filter with a water separator on the tank.
Bad fuel has taken out a lot of trucks and tractors.
   / Water in fuel causes $10,000 damage to my Kubota Grand L6060 #6
Well that really sucks.
I would've imagined that such an expensive tractor with such a sensitive fuel system would at least have a Water in fuel sensor that would send a warning on the dash.
   / Water in fuel causes $10,000 damage to my Kubota Grand L6060 #7
In 37 years of driving diesel cars and 18 years diesel tractors, I've never ever had water in diesel, in gasoline yes.
   / Water in fuel causes $10,000 damage to my Kubota Grand L6060 #8
There’s a reason there’s usually dual filters on those tanks. Then a separator and filter, or two, on the tractor.
How long was the tractor sitting like that to rust? I can’t imagine it ran with enough water to rust the rail.
   / Water in fuel causes $10,000 damage to my Kubota Grand L6060 #9
You must be blessed. I have and more than once.
   / Water in fuel causes $10,000 damage to my Kubota Grand L6060 #10
Your problem is 24,000 psi injector system. I worked at Kubota when that was coming out. We had a cab tractor in with just 16 hours on it. They were saying bad fuel. I was saying not enough filter to clean the fuel. Just Kubota and me talking. I didn't know the owner.
LMC LOT IDENTIFIER 9 (A53084)
LMC LOT IDENTIFIER...
UNUSED FUTURE ELECTRIC MASSAGE CHAIR (A51248)
UNUSED FUTURE...
66 Tomahawk Skid Steer Bucket (A52384)
66 Tomahawk Skid...
SKYJACK SJIII 3226 ELECTRIC SCISSOR LIFT (A51246)
SKYJACK SJIII 3226...
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
