vongiese
- Joined
- Mar 29, 2002
- Messages
- 165
- Location
- NW Montana
- Tractor
- Yanmar 2210D, Sany SY35 Excavator, Kubota 4060LE,
Tractor - 2210D - has been getting harder to start....
Had water in fuel....cleaned tank, still had water in my fuel bowl couple days later - cleaned it out.
Still hard to start - starts on one cylinder - then the other will kick in, but would run fine then....was thinking bad ring or bad injector and started a post......then
Tried to start her after work yesterday and literally got showered in oil/water mix ....I removed the muffler and a green and slightly black antifreeze mix came flowing out of the exhaust chamber.
Norm responded: Hopefully it's only a blown head gasket. Might as well get one, and a rocker arm cover gasket, on order before tearing it down.
thanks norm!
Any other recommendations? I suppose I should go ahead and check other things to see what condition themotor is in like compression, others? Other parts I'll need?? special proceedures? I have the IT and manual for a 240, but I imagine the specs for my motor are a little different?
thanks
thanks norm!
thanks
