Water Pump Needed
   / Water Pump Needed #1
Diamondpilot
Super Star Member
Daleville, IN
Jinma 254/284 Ford 861 Powermaster at work
I have a Bolens G 152 tractor which has an Iseki 3 cyl diesel in desperate need of a water pump. When looking on line I can't find any Iseki diesels on this model nor any manuals or dealers with parts. Can anyone help. This is for a friends tractor and I am just trying to help out.
Chris
   / Water Pump Needed #3
I can supply you with a water pump & most parts for Bolens/Iseki tractors.. Feel free to email me.
   / Water Pump Needed
Thanks. I will pass on the links to my friend.
Chris
   / Water Pump Needed #5
Chris,
Perhaps you would have better luck removing the pump and replacing only the parts you need, such as the water pump bearing and seal. These two items may be easily located at your local bearing supplier once the part numbers and sizes are obtained. It may be that the tools necessary to remove and replace these parts are cheaper then the replacement water pump and these can be reused, sold or traded after the repairs are made.
Please let us know how you ultimately solve this problem.
Good luck
RB
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
3in Poly Pipe (A49461)
2020 Mesa Ridge 32ft Lite Travel Trailer (A49461)
2020 Mesa Ridge...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
