water pump on bolens g274(iseki 4270)
   / water pump on bolens g274(iseki 4270) #1
wises4057
Wisconsin Rapids
Bolens G274
so I am attempting to put a new water pump on my Bolens G274(2074) tractor. I was not the one who took the original water pump off, and am now having an issue figuring out what bolts are suppose to go where. I am by no means mechanically inclined, i just want to make sure that im putting everything back on how it came off(plus im not sure i have all bolts required, person who took it off may have lost a few). Does anyone have a walk through on it, or a pdf service manual file that they could send me? Any help would be appreciated! You can e-mail me at Seth_wise@hotmail.com.
Again, Thank you!
Seth
   / water pump on bolens g274(iseki 4270) #2
Hey Seth!
I just dropped-in here at Iseki forum to follow-up on my ignition-switch question, and saw your query about water pump problems.
My son bought a Bolens-Iseki G194 which developed a waterpump (leakage) problem, and I had great luck with the DESSCO company in Utah (see my water- pump related post in Sept. and Oct. 2009). I had such great luck with the folks at DESSCO that I wrote their owner a letter commending his Parts Dept. personnel. But they WERE great, steered me 'right' and got me the correct part, etc., for cheap-money price too, so I have no problem in doing personal advertising for them (b.t.w., I'm located in NH).
Like you, I'm no mechanic.... so I used a local guy who IS a mechanic, he came over one Sat. morning with tools, pulled the belt-pully wheel, removed the fan and then replaced the water-pump. Am pretty sure he used the gasket that came with the pump, he might have painted it up with some gasket sealer too, but I don't recall for sure. Anyway, the whole thing took him less than an hour, and it wasn't brain-surgery that's for-sure.
I don't know how your tractor is set-up, but assume its mechanics would be similar to our G194 in operation and design. On ours the seals around the shaft of the W/P were just worn-out; I could have had it rebuilt for $350., and there were LOTS of folks who wanted to sell me a new W/P for $400+,
but DESSCO fixed me up with new pump for about $150.
Good luck ! If your tractor isn't working now, go ahead & try this repair yourself.... if it doesn't work afterwards, you haven't lost any ground.
J. Henley
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
2023 JOHN DEERE 8R310 LOT NUMBER 202 (A53084)
2023 JOHN DEERE...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
2017 Rogator RG1300B Dry Fertilizer Applicator (A53472)
2017 Rogator...
