allenp
As a winter project, I added a YM2000 water pump on my YM1700 and would like opinions on adding a thermostat in the upper radiator hose. In doing some checking, most of the grays that have a water pump do not have a thermostat. Even some of the US versions, YM195 & YM240 for example, use the same water pump and radiator but also do not have a thermostat. For this reason I would suspect that the 195 runs cooler and takes longer to warm up as compared to the 240. Same goes for some of the gray Yanmars. But on the other hand, these tractors have been around a long time so I don’t think running a little cool or hot is much of an issue.
I am not that familiar with water pump design and concerned about the pressure becoming too high until the thermostat opens. Obviously with a thermostat in the heater hose (Ford 8N for example), you do run the risk of the upper hose blowing off. In researching old postings I noticed that of users that have a water pump and automotive temperature gauge, the temperature is relatively low (120F-140F). On thermosiphon systems, the temperature is more in the range of 180-230F…and VERY sensitive to angle of travel, cleanliness of cooling system, coolant mix ratio, etc. One thing I have found out on my YM1700 is the temperature of the coolant is approximately 20F higher that measured on the automotive gauge. I would assume that this is partially due to the sensor being located in a cavity and not directly in the coolant flow.
Based on limited used since the pump was installed, the temp stays around 100 under no load conditions. Under use, the temp runs in the range of 120-150, depending on the load. Regardless of the condition, I see no white smoke while running.
Any and all comments would be appreciated.
Allen
Allen
