mobilus
Bronze Member
I'm sure someone here has the answer...
I've laid 1" poly tubing about 450' from the dock on our big pod to our small pond which is a few feet higher I elevation. If the situation was reversed, I wouldn't need a pump...however, I do. Here's the question: what's the better deal, running a larger 2" pump (2 in. 212cc Gasoline Engine Semi-Trash Water Pump - 158 GPM) for $199, or a 1" pump (1 in. 79cc Gasoline Engine Clear Water Pump - 35 GPM) for $165? I know that I can only push so much water through the 1" tubing at a certain pressure, and the efficiency of the motor/capability of the pump are factors as well, but which is the better option? If I had electricity back there, I'd use an old pool pump. Your thoughts?
