Rmally
Bronze Member
Hey folks,
We are about 3 weeks from moving in to the new house. Next week they are moving the pressure bladder tank to the crawl space and will be hooking up the water. Here's my questions:
1. When the pump cycles if your in the shower do you loose a lot of water pressure?
2. Can you use multiple faucets with good pressure?
3. How do I know the optimal setting for setting the pressure in the bladder tank? I've watched so many videos but still confused.
As of right now the tank is still outside beside the casing. The air pressure in the tank is around 30ish lbs and it appears when the tank hits 30ish it fills back up and cuts back off around 55 or 60. I'm getting 12-14 gallons a minute with a 1hp pump. I noticed this week when rinsing off some equipment the pressure from the hose dropped off dramatically every time it cycled. I was using a lot of pressure and water so nothing like a shower head but that got me thinking about the above questions.
My tank is 25 gallons, should I get a bigger one for the crawl space.
Any input would be great.
