wd 45
   / wd 45 #1
funny farmer
northren mn
ford 4000
I hope this is the right forum for this.
A buddy of mine brought home a wd 45 the other day. The first thing he broke was the shifter. The shifter would move around, but it was stuck in 3rd gear. The guy that he got it from said that sometimes it does that. I removed the 6 bolts on the tranny cover, made sure the stick was in the 3rd gear position, picked up the whole assembly, and set it down in place. Somehow whatever was disconnected was fixed, so I tighten the bolts back down, and told him not to do that again. So what is really going on in there? I'm assuming that its between the shift lever and the fork, but it doesn't look like I can get in there and fix anything. Is there a way to fix this? For some reason just because I own a couple of tractors and make some hay, he thinks I'm a mechanic too. I'm handy on some things but I don't know anything about these old tractors.
Next thing, I can't figure out how to get his 3 pt. to work. The lever that suppose to operate the 3 pt. is hooked up to a loader,and all it does is raise and lower it. He wants me to put a dump on his loader, but I don't think there's any way to do it. I can't even get the 3 pt. figured out. I did watch some videos on utube, and I'll go back over there later to look it over again. For now I'm stumped.... Maybe there's only so many things that you can do with these older tractors.
   / wd 45 #2
First, getting stuck in between gears is common on older 45's tell him to be very definate in his shift pattern and slow. We owned a CA and a WD 45 both had the same problem when they got older.
Second, the 3 pth is not factory. The WD 45 had a coupler system and only took AC equipment that needed to be lifted. Many people altered them to make 3 pht though. I have no idea who to operate one without the other.
Don
   / wd 45
Thanks for the reply.
I was thinking that if he wanted a loader with hydraulic dump, that he'll have to get an aux. pump hooked up to the p.t.o shaft and have separate controls off of that.
As far as the 3 pt. I have a couple of neighbors that have the same tractor. So today I'll go over and check out there set up, and see if I can't cobble something together. Thanks again.
   / wd 45 #4
I have a WD that is a couple years older than the WD45. It has a gate valve below the hydraulic reservoir that has to be opened to run the loader. Close it to hold the loader up and run the rear lift.
The guys at allischalmers.com can probably answer the gear stuck question or hook you up with a 3 point conversion. I used ford parts to convert mine when I bought it 14 years ago. Tractor is sitting in fence row now with an antifreeze in the oil issue.
   / wd 45 #5
many times the shifter nub wears.. you can usually braze or weld the nub up and then file or grind it some to make it engage more positively..
soundguy
   / wd 45
Thanks guy's, I ended up installing a valve on the hose going to the loader, that way when he wants to use his 3 pt, he can just turn the valve to the loader off. We bought some ford lift arms, and a new center link. I hooked a chain from the original lift arms to the new ones, so now he can buy all kinds of different attachments.
Next thing he wants me to do is get his hydraulic bucket plumed in and working. If I have time, I might be working out of state for a while. What I was going to do is, run that line that I put the valve on into a dual control lever box. That way he can turn that valve on, pull the lever up that controls the hydraulics on the steering wheel, and he should have a working f.e.l. I don't think that we'll have to hook up an aux. hydraulic pump just for what little he wants to use it for.:thumbsup:
   / wd 45 #7
Hey funny farmer. I just wanted to say that your pal is sure lucky to have such a great buddy! I bet it's fun for you to help your freind but at the same time Kudos to you.:thumbsup:
   / wd 45 #8
kinda like public tech supt!
soundguy
   / wd 45
It's funny how I run over to his place to work on his tractor when there's plenty I should be doing to mine right now. I wanted to get the mother in laws ford 2000 going to so we can use it to rake hay with this year. But, still it sits. Maybe that's what I'll do today.:thumbsup:
   / wd 45 #10
3 cyl or 4 cyl? gas or diesel?
soundguy
   / wd 45
soundguy
3 cyl gas, the neighborhood mechanic installed an alt. on it and didn't hook up any wires. So now I have 3 wires that I have no idea where to hook them to. I have a book on it, and I should be able to figure it out, maybe. And before that it would require a jump from my pickup, but after it was running, it would die when I unhooked the neg. jumper cable. So I would think that the neg cable is bad, or it's the ground to frame.
I went over to her place to work on it last fall. The battery was gone, and the mother in law had the key on her, and she was in town, so I went home and for some reason I gave up on the idea.
   / wd 45 #12
well.. if it needed a jump that told you the battery was dead...
if the alternator is not hooked up.. it's not making power for the ignition.
since it's a gasser.. it needs electrons for the spark ignition system to run... no big mystery there why it dies when you pull the jumper cables off...
is the alternator a internally regulated Delco 10SI or 12SI ( post a pic of it, including the back ).. or something older with an external reg like a declo 10DN.. or even different like a motorola?
soundguy
   / wd 45
I'll run down and get a picture of it later today. It would die like that before the new alternator was installed, but that would make sense if it was bad.
   / wd 45
picture.php
The post that I have the wire hooked up to is marked with a bat, I assume that runs to the battery. The other end of this wire is hooked up to the same post that the positive battery cable is hooked up to.
There is a 2 prong plug on the other side of the alternator that is plugged in. I'm not sure where the other end of these wires go to.
The one wire left without anywhere to hook it up, would what I assume to be for the tack sensor, which is no longer available on an alternator the way is was on the older generator.
It looks to me like it should work the way it's hooked up now. The bad thing is, I noticed today that the neg cable is corroded where it bolts into the frame. If I clean that up and put a good battery in it, we should have no problems. Right????:)
   / wd 45 #15
Ok.. lets clear some things up.
the old 2000 didn't have a tach sensor on the genny.. it had a mechanical tach drive that ran a cable to the proofmeter.
a delco 10DN that uses an external regulator has a tach drive compatible with the lucas generator.
( pre 65 ford 2000 had the tach driven off the hyd pump )
a delco 10 or 12 SI.. which is what it looks like you have is a 3 wire setup.
big bat stud on back is for charging the battery.
the lil plug is on 2 spade terminals.. marked #1 and #2
#1 should have a wire that runs thru a lamp to key switch power. the dash lamp for charge will suffice. IE.. find the wire from the dash cluster that is for the charge lamp.. run this wire to #1.. when you turn the key on, 2 lamps should light up.. the charge lamp and the oil pressure lamp. once you start her up and oil pressure comes up the oil lamp goes off.. and once the alternator kicks in the charge lamp goes off.
the other spade terminal #2 is looped over to the charge stud to adjust the votlage regulator output.. on a car.. that wire would go back to the battery to measure and make up for voltage drop in the 30-40' of wire harness.. in a tractor with 3' or wire harness.. you just hook it over to the charge stud... it's likely the one wire you have left is for this.. but I would trace it.
soundguy
   / wd 45 #16
hit reply too soon.
yep.. clean up all connections and get that alt hooke dup.. don't run it without the sense wire hooekd up as it can let the voltage spike to about 17v.
also.. they DO make alternators with electrical tach hookups..
soundguy
   / wd 45
Thanks soundguy for all your advise.....
It's funny, I said it was 3 cylinder gas. It turns out that it's 4 cylinder gas. My book covers 3 cylinder gas and diesel, 2, 3, and 4000 series. Why would this one have 4 cylinders, unless it isn't a 2000 series like we've been calling it for years.
I hooked the alternator up the same way as it is on my 4000. I need to put a new battery in it, because even jumping it with my truck for an hour isn't enough to turn it over, it just buzzes at me. I can jump the starter to get it to turn over but it still doesn't fire. I'm not sure if it even has any spark, lack of help. I doubt if I'll get to it today, maybe this weekend. Heck, it took me 2 years just to get the water pump in my 4000. I haven't tested it yet in the real world yet, that will be this weekend too. Check my thread I started over a year ago.:) Ya, I'm that bad of a procrastinator. At least that leave's me something to work at in my personal life.
I think that my best bet would be to start a new thread..
   / wd 45 #18
4 cyl gasser could be a 2000.. but it would be a 63/64 model.. and essentially the same as the 601 series.
post a pic, and post the numbers off the bellhousing flat aft of the starter.
I'll decode them for you.
soundguy
   / wd 45
soundguy
That would make sense then. All my book says is before 1968 and after 1968. I'll get a picture of her this weekend and post it in a new thread in the vintage ford section, thanks.
   / wd 45 #20
that is refering to a 3 cyl.. there were some changes in 4-68.. also the model ID number 1st digit changed from numbers to letters.. etc.
4 cyl older 2000's have a different model ID code than the 3 cyl jobs.
soundguy
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
