wear does it go.
   / wear does it go. #1
herbie the lovebug
whites creek ,tn
john deere 170
i have a jd 170 lawn tractor. how& wear does the height adjustment spring attach, the lever is on left side &ankle high.
   / wear does it go. #2
What spring are you referring to? Is it the large 'Lift assist' spring? This is the spring that makes it easier to lift the deck from it's lowered set height position.
If so, one end is hooked to the frame near the front axle beam. The other end is hooked to the slotted link that connects to the lift lever.. The spring has significant tension, and is difficult or dangerous to install.
   / wear does it go.
no, its a small spring that attaches somewhere on or around a notched cam device that holds pressure on the mower deck height adjustment lever which is located on the lower left fender.
MAHINDRA 2810 TRACTOR (A54756)
MAHINDRA 2810...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2007 JOHN DEERE 700J XLT CRAWLER DOZER (A52705)
2007 JOHN DEERE...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
1065 (A53342)
1065 (A53342)
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
