weed wacker broke
   / weed wacker broke #1
Nik
Bucks County, PA
B3030 Kubota HST
Tried to help my brother with his sears 32cc weedwacker. The primer bulb that you use for the fuel is sucked in (cavitated inward) and will not relax for additional priming. Is this due to a vacuum in the fuel line? Can I just disconnect the fuel line to the bulb to fix this?
   / weed wacker broke #2
If it is like the one on my Ryobi trimmer it sucks fuel from the tank, through the carb. If yours does work that way the fuel filter (on mine...in the tank) might be stopped up, trash in carb, or a fuel line crimped causing the problem, as you suspected from vacuum. You could disconnect one line (the one from the carb) to relieve it. If you remove the line you might shoot some aerosol carb cleaner into the carb through the tube. This might dislodge or clean the carb a little, but I would pump some fuel through it pretty quick. It might damage the diaphram or o rings if left full strength for very long.
BRAKE PADS (A53843)
BRAKE PADS (A53843)
2015 CAT D5K2 LGP (A47477)
2015 CAT D5K2 LGP...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A53421)
Toro GreensMaster...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
