Weed Wipes
   / Weed Wipes #1
Tyrun
Owingsville, KY
New Holland 1510TL
Has anyone Tried a Weed Wipe behind their tractor to control weeds in hay fields? I would like to know how well they work and which brands you'd recommend. It appears that there are quite a number on the market of different designs/features. Any advice would be greatly appreciated.
   / Weed Wipes #2
I've been reading up on them myself. Some seem pretty darn expensive for what seems like such a simple design. So simple in fact there are plans to build your own.
There are several studies online, here is one I read. http://jefferson.ext.wvu.edu/r/download/50645
   / Weed Wipes #3
I built a 10 wide weed wiper from a kit. I supplied the 3 inch PVC pipe, mounted on the FEL. It worked well on the weeds the wiper contacted. BUT. (there's always a but) 10 feet wide is a long time to spend in a 10 acre field. Can't go very fast or the wiping action is minimized and the weeds survive. If it's built wider say... 30 feet the field has to be level like a billard table or the wiper has to accomodate the field contours.
   / Weed Wipes
Thanks for the reference. It answered some questions I had about rotary wipers.
   / Weed Wipes
I have a 42 acre field and it's not all level. In fact, it's rather hilly. Last fall I had a terrible time with Johnson grass taking over. My hayer suggested I use a weed wiper. I want to get some input before I go out and invest in one so any advice is appreciated. Thanks.
   / Weed Wipes #6
I'm dealing with a Johnson Grass problem, too. I was asking around in my area (NE Kansas) and had several options recommended, but the weed wiper seemed the most feasible. Other options included some very expensive chemical designed to just take out Johnson Grass, and another was overgrazing heavily early in the year, but I was too late last year. This year our drought conditions may not make that feasible, as my neighbor who would have brought in the cattle to overgraze got rid of his herd. Not enough pasture, not enough hay to cut, and hardly any water in the ponds.
It's looking like the weed wiper may have to wait another year. Last years lack of moisture ended up being the problem then, as the Johnson Grass never got tall enough to use a weed wiper. And this year may be worse......
   / Weed Wipes #7
I use a 15' in my fields. Works well. Actually wanting to sell it and get a wider one. If your terrain is very hilly/uneven, 15' is the max width I'd recommend in a fixed unit.
   / Weed Wipes
Is yours a fixed or rotational type weed wiper?
   / Weed Wipes #10
Sorry for the delay. I'm in east TX. Mine is a hydraulic rotational fixed (non flex wing). It us a well built unit and I believe the rotation definitely helps with the application of chemical. It gives the targeted weeds a thorough application of chemical.
   / Weed Wipes #11
How much $$$$$$?
   / Weed Wipes #12
PM me and we can discuss. Just been kicking it around so far...
   / Weed Wipes #13
I sent you a PM but no response. Maybe it's lost in cyberspace. Update: I got your PM. It was my fault for looking in the wrong place for it.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
2016 BOBCAT T590 SKID STEER (A60429)
2016 BOBCAT T590...
