weight capacity 3 point hitch B1550
   / weight capacity 3 point hitch B1550 #1
sw18x
Bronze Member
Looking
I'm looking at a used B1550. One job I could definitely use help with is lifting logs onto a wood splitter. We have an outdoor woodburner and get chunks delivered as big as a couple hundred pounds. I'm wondering what kind of weight the hitch on this tractor could handle if I put a crane boom on. It's a type I hitch according to Tractordata.com, and the machine itself weighs around 1100 pounds. Thanks.
   / weight capacity 3 point hitch B1550 #2
Maybe 400 - 500 lbs
   / weight capacity 3 point hitch B1550 #3
Just a guess based on my BX1850 which is similar in weight. The 3PH will lift around 900 lbs at the lift arms and around 600 lbs 24" out. How far back is this crane boom going to extend. Do you have any weight on the front of tractor?
200 lbs should not be an issue as long as it is not to far back. Just remember weight up high makes things tip easier...
Roy
Thanks...I'm leaning towards going big and getting a BX1860 or 2360...now if I can only get the wife to agree!
1982 De Lorean Tug (A44391)
1982 De Lorean Tug...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A43004)
2021 FREIGHTLINER...
2016 Ford F-250 Knapheide Service Truck (A44571)
2016 Ford F-250...
LOAD OUT AND SHIPPING (A44391)
LOAD OUT AND...
2017 Ford Fusion SE Sedan (A44572)
2017 Ford Fusion...
2016 Chevrolet Equinox LS SUV (A44572)
2016 Chevrolet...
