Weight capacity of axels
   / Weight capacity of axels #1
paul dyar
Bronze Member
Anderson S.C.
TC33DA
Any way of telling the weight capacity of axels. I have a converted boat trailer with tandem axels and would like to know what capacity they are.
Thanks, Paul
   / Weight capacity of axels #2
There seems to be a telltale signs from how many bolts to hold wheels. If 4 then it probably 2k rating. If 5-6 its probably 3500k rating. etc. This is not the bible absolute, but the general idea. Why not check the tire ratings itself ? the weakest link of trailers is either the tire or axle.
   / Weight capacity of axels #3
Oh I'd take what radioman said to the next level...
TIRES are the "weakest link", they are the only thing that will get you - BAD. Bearings will take 2x the load pretty well if properly lubricated but the tires will not take even 1.5x rated load when new for very long.
My suggestion is, when in doubt, use the actual tire ratings at 90% and not a pound more.
   / Weight capacity of axels #4
What these guys said is the truth for the most part.
In general 5 lug = 3,500# and will have 14" or 15" wheels
6 lug = 5,200# or 6,000# and will have 15" wheels
8 lug = 7,000# will have 16" wheels
Anything with 13" wheels can be 4 or 5 lug and 2,000# or less axles. Smaller wheels, like on a jet ski trailer or log splitter, are commonly 4 or 5 lug and 1,200# axles.
Like mentioned tires are usually the limiting factor.
Close pictures will tell me a lot. I am a boat trailer dealer and while I have not seen it all I deal with plenty of stuff.
Chris
   / Weight capacity of axels #5
I went to a trailer dealer when looking for replacement bearings and he told me the axle ratings...
Thank for the replies. Will try to get pictures.
Paul
   / Weight capacity of axels #7
Many trailer axles come with a metal band around the axle tubes with the GAWR numbers stamped on the band.
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
Wooden Barge Wagon (A50515)
Wooden Barge Wagon...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
Hay Forks (A50515)
Hay Forks (A50515)
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
