WEIGHT OF HARDEE 7' CUTTER
   / WEIGHT OF HARDEE 7' CUTTER #1
DIRTROAD
Platinum Member
SOUTH CAROLINA
MF231, MF240, CAT D4K2
Does anyone know the weight of a 7' Hardee model 984LTW. It is a dual tail wheel model. I am just trying to figure out if my tractor will handle it.
   / WEIGHT OF HARDEE 7' CUTTER #2
Hey dirtroad, I'm in Lexington not that far from you. I have a 5ft International medium duty mower with a single tailwheel and it weighs right at 600lbs including the slipclutch. I would guesstimate your 7 foot mower with dual tail wheels would probably weigh right close to 900lbs. In other words, it's a hoss!! What size tractor do you have??? Maybe others here can help you out a little better if you tell us the combination you're looking at putting together....
   / WEIGHT OF HARDEE 7' CUTTER #3
hardee website says single tailwheel 90 hp gearbox weighs just over 1000 lbs heavier two tail wheel model with 125 hp gearbox weighs over 1400 lbs
2015 Ford Focus (A51694)
2015 Ford Focus...
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A53421)
2025 GIYI Stump...
1995 Ford L8000 Grain Truck GARAGE KEPT (A55301)
1995 Ford L8000...
2013 SHOP BUILT FLARE STACK (A53843)
2013 SHOP BUILT...
2016 FREIGHTLINER CASCADIA DAYCAB (A53843)
2016 FREIGHTLINER...
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
