LincTex
Hey All,
I just picked up a pretty nice TYM/Mahindra 4110 at an auction "with a new clutch"
Well, it runs and drives great as long as you never push the clutch in!
Then I get the weirdest grinding noise, almost like two plastic hair combs rubbing together very fast.
It doesn't necessarily sound "metallic".
Clutch out and driving around, the clutch "grabs" very well - step on the brakes and you can almost lock up the rear wheels while the front wheels keep pulling you along!
When driving along and you push the clutch in - - as the tractor slows (while still in gear) and the input shaft speed subsequently slows down, the grinding sound frequency INCREASES (starts very low while flywheel and input shaft at near same speed) and is at the highest noise when the input shaft RPM is at zero with the engine running and clutch in.
It DOES NOT sound like a bad pilot bearing at all.... that's really the only part (well, besides the clutch disc itself)..... Hmm, maybe i am on to something here - - what would cause a clutch disc to make a noise like that? When input shaft speed is zero and engine running?
I'm pretty sure I will need to split the tractor to fix this, which I feel confident doing
Can anyone send me the manual page copies that show how to set-up the clutch on the bench?
THANKS IN ADVANCE!
THANKS IN ADVANCE!
