Weld Pac 100
Status
Not open for further replies.
   / Weld Pac 100 #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
Anyone have a Lincoln Weld-Pac 100 welder? If so do you like it? thanks, bw
   / Weld Pac 100 #2
Hello BrettW,
I have the Lincoln Weldpac 100, have had it for several years and works great. A nice selection of heat ranges and wire feed speeds. I like the portability of the unit with the 110v power.
   / Weld Pac 100 #3
Hi,
I have the Lincoln 135 which is just a bit bigger then the Weld-Pac 100. I think mine costs a bit more but is still in the realm of "cheap welder".
Lincoln certainly makes a good product, but whether you will be happy with it probably depends on what you want to do with it. If you are trying to weld 1" thick steel, you might want something a little heavier duty. I think the 135 is rated for 5/16", which handles most of what I'm likely to need. I think the 100 was rated for 3/16", which was a light for my needs.
have fun,
sf
Status
2014 PETERBILT 367 (A48992)
2014 PETERBILT 367...
LEUS XR3037 4WD Tractor (A49251)
LEUS XR3037 4WD...
377878 (A48837)
377878 (A48837)
DRILL PIPE (A48992)
DRILL PIPE (A48992)
2 3/8 DRILL PIPE (A48992)
2 3/8 DRILL PIPE...
2013 Ford Explorer SUV (A48082)
2013 Ford Explorer...
