Hi, I am building a subframe for a backhoe on my JD 4120. I need to do some of the welding while the frame is on the tractor. How do I prevent damage to electrical components while I am welding?
YES,ditto on the battery cable.ALSO dont put your grounding clamp on the opposite side of a bearing so electricity is passing through it.dont ask me how i know /forums/images/graemlins/frown.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/grin.gifALAN
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Ditto what the others said. In general I try to "not" weld on a tractor.. but if I have to.. I disconnect the lines to the alternator, pull bat cables, and then put the ground clamp as close as practicle to the area being welded.. and as others said... don't let bearings conduct welding current!
Ok, so far I have: disconnect battery and alternator, ground right next to the weld, don’t fry bearings and limit it to the minimum amount of welding I can get by with. Anything else before I start?
If your tractor has an ECM or other computer components you should remove it before welding. Doesn't matter if the battery is disconnected or not, you could still fry the system.
</font><font color="blue" class="small">( So long as you don't connect the welder right to the battery it won't be part of the circuit. There is no need to disconnect it. )</font>
In theory, that works.. However I have seen at lest a few examples of sensitive electronics on a car/truck damaged from welding ont he vehicle with everything hooked up. By disconnecting the battery.. you isolate the rest of the car.. that's why I like to disconnect it...
