Welding on a Tractor
   / Welding on a Tractor #1
EricM
Indio, California
Yanmar YM2000,FX265D,YM3110D
I have a spring bracket that broke off towards the lower half of the transmission case (thick metal area). I need to weld it back on. Are there any special concerns when doing this? Any explosion or fire risk? Do I need to drain the hydraulic fluid?
   / Welding on a Tractor #2
Consider the following: 1. keep the ground clamp for the electric arc welder near where you are welding. 2. Draining hydraulic fluid sounds good. 3. leave fill cap cracked open a little so expanding gasses can escape. 4. undo battery and altanator wires. You don't want to burn out any diods inside. 5. You are probably welding on a casting. Watch your heat level.
Dick
   / Welding on a Tractor #3
First. Is it cast iron that you are welding? If so. You need to use a suitable electrode ( made for cast). Preheat the area gently with a propane torch to pre-expand the metal and prvent heat cracking. I wouldn't drain the fluid, as this will help to disipate the heat from the welder. It won't take long enough to create enough fumes to be a fire hazzard. If in doubt do it in 2 attempts rather than build up to much heat in one go.
Alternate choice. If the is a stud or bolt nearby, you might make a bracket to fastem to the bolt and attach the spring to it.
   / Welding on a Tractor #4
Might even try brasing it.. or using your propane torch and one of those allow solder rods made for cast and aluminum.. just depends on the strength you need.
Soundguy
   / Welding on a Tractor #5
Apparently I missed the part about your arc welder, as opposed to acetylene. Do we assume you are using an arc welder?
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
LEGEND  2615 (15) BAT WING (A52472)
LEGEND 2615 (15)...
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
2015 KENWORTH T680 (INOPERABLE) (A52472)
2015 KENWORTH T680...
New Long Forks (A53002)
New Long Forks...
