Welding on Mesh Protection?
   / Welding on Mesh Protection? #1
gwstang
Platinum Member
Lake Martin Alabama
1952 Ford 8N / Kubota L2501
I finally made it by to pick up another bottle of MIG gas so I can tack weld the wire to the brush guard. My question is: Do I need to remove the grill guard to do this welding? The reason I ask is that I don't want to mess up any electronics or such. You know how "fragile" these new babies....erhhhh-uuh... tractors are. :laughing: What does the brain trust say? :confused:
   / Welding on Mesh Protection? #2
This topic has been thoroughly discussed in the "Welding" forum here on TBN.
You might want to go there and search. Opinions vary.
I didn't even think about the welding forum :ashamed:
   / Welding on Mesh Protection? #4
I say take the guard off.It will be easier to weld in the flat position and it will keep the spatter from marking up your paint.It will also give you more room to work on it.
   / Welding on Mesh Protection? #5
Something as easy to pull off as the grill guard, better safe than sorry.
I think generally it is considered safe to remove the ground off the battery and ground the welder close to your welding.
2012 FREIGHTLINER M2 TANDEM AXLE DUMP TRUCK WITH A SNOW PLOW (A51222)
2012 FREIGHTLINER...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A51039)
2022 Gravely...
2015 VOLVO TRUCK VN SERIES (A50854)
2015 VOLVO TRUCK...
2014 MAGNUM PRODUCTS LIGHT TOWER (A50854)
2014 MAGNUM...
2012 GALLEGOS TRAILER 130BBL VAC TRAILER (A50854)
2012 GALLEGOS...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
