beowulf
Veteran Member
- Joined
- Dec 31, 2003
- Messages
- 1,186
- Location
- Central California Foothills
- Tractor
- Kubota L3410 HST, J Deere riding mower
We have a deep water well with pump down about 400 feet. We have experienced what I would describe as "water hammer" sounds in the house. It is a bit difficult to determine precisely where the sound comes from (seems sort of a general sound - sometimes I think I can hear it at the hot water heater, sometime in walls near one bathroom, but not always). The sounds are definite but a bit subtle - i.e., not a severe banging but clearly annoying - and concerning. After discounting that the house was haunted, I cannot link the periodic thumping to anything else other than the well-pump when it kick on or off. We replaced the pressure tank and the check valve in February. We were experiencing some of the same sounds before those replacements but the sounds continue - and perhaps are a bit more frequent now. Pressure switch is at 40-60.
Other potentially relevant information:
- when the water is drawn down to 40psi (the kick-on point), at that precise point when the pressure reading gauge goes to 40, it then drops immediately to about zero, fluctuates rapidly (sort of bounces a bit below the 40 mark) and then goes to 40 as the pump kicks on. All of that lasts for about one second. That is, the needle does not simply stay at 40 and then steadily climb as it kicks on, but dances a bit first. I don't know if that is normal or symptomatic of some issue.
-the home is about 80-90 feet from the well. The pipes from the well are galvanized pipe and I think 2" dia, and perhaps 18"+ inches under ground and run to the house, with split-offs to a guest house run and for outside bibs. The house run pops up near the house, to a simple filter and then to a 3/4 inch line supply under the house which runs in a crawl space. -when I turn on a faucet in the bathroom I can sometimes hear a barely audible bump - unless you listen for it and are aware it might happen you would never notice it.
I am about to have a well service company come out and evaluate things at the well (e.g., faulty check valve slamming - even though new in February, or whatever), but thought I would first post here - to educate myself before I call - or perhaps avoid the call.
Although the sound seems more general than identified to specific areas (such as in a particular bathroom) I am aware that the sounds of loose pipes can resonate throughout the house a bit and thus I may need to drag and contort my 74 year old self down into the crawl space and drag myself around under there to attach pipe straps here and there (or open up walls to check on the vertical pipes behind showers, etc.) but that is not something I really look forward to doing - I would rather chew on tin foil for a day.
The hammer sounds do not appear to exist at all in the guest apartment building (new in 2009) which is much farther from the well (perhaps 200 feet), and which is supplied by a T off of the well line before it gets to the house, and then runs with 1 1/2 inch PVC, and then goes into the attic area using PEX.
My questions are:
-Is there a water hammer absorption (?) device for wells (i.e., not just one designed for a particular appliance or in-side location) that can be installed in-line that might resolve this - or is such not recommended?
-Any suggestions as to the cause and regarding anything I can do to address this?
Sorry for the long narrative, but I like to provide as much information as possible as I am not certain what might be relevant to a solution. As always, thanks in advance for reading this and for any suggestions. I always greatly appreciate the help I receive here - if you can save this old man from a trip into the very low crawl space, I will buy the beer.
My questions are:
