Search Results - TractorByNet.com search is your friend.
He used the Google search box at the top right part of the page and entered "snow plow ssqa"Fallon
I don't mean to sound stupid but how did you come up with these search results? I click on search and then type what I want to search and I get all kinds of threads but they don't seem to be what I'm searching and I wonder why I'm always frustrated with searching. I'd like to know how you go about getting your results and what did you search when getting these results for plow?
Unplug the hoses coming out of your joystick that would go to the bucket curl cylinders. Plug the hoses from the angle cylinders on the blade into those ports. You should just need to make sure your plow has proper pressure relief valves in place as I hear plows run at lower pressures than tractors (2,000psi). If you have all the plow plumbing already, you should have proper relief.
