What are short falls of jd2210
   / What are short falls of jd2210 #1
bones72
Jd2210
Bones72
   / What are short falls of jd2210 #2
Lots of reviews here (problems with link)
   / What are short falls of jd2210 #4
They are light little tractors. I prefer a heavy tractor for traction and pulling power. Weak 3 point lift at 700#. Also low ground clearance.
I call these type of tractors Suburb Tractors or Estate Tractors.
Chris
   / What are short falls of jd2210 #5
perrhaps the op would be better off giving more detail on what he plans to do with said tractor so the members of this site could give better insight if the tractor would be a good tractor or not. diamondpilot makes a good point
   / What are short falls of jd2210 #6
If the primary task is mowing and other chores typical of a 1-2 acre residential owner...good tractor.
Any more acreage or heavier tasks, probably too small.
   / What are short falls of jd2210 #7
Way to small for any serious work. For mowing the lawn and pushing a little snow it would probably be fine. IMHO something in the 35 horsepower range would serve you better.
   / What are short falls of jd2210 #8
One if the biggest repair items was the transmission coolant fan located underneath the tractor, where every single piece of debris would find its way up to hit it :-(
Brian
   / What are short falls of jd2210 #9
also it has Limited Cat 1 hitch..
b
Peterbilt 377 Semi-Truck (A52128)
Peterbilt 377...
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A51242)
2022 CATERPILLAR...
1240 (A50490)
1240 (A50490)
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
30' Harvest Hand Head Cart (A50514)
30' Harvest Hand...
