What can a X7xx lift on the rear 3ph?
   / What can a X7xx lift on the rear 3ph? #1
MetalChicken
Bronze Member
Chester - UK
Case 4230
Just thinking out loud here. I was wondering if an X740 fitted with a rear 3ph could lift much on a pair of pallet forks. I can't find the spec anywhere - anyone have an idea of what it can handle?
   / What can a X7xx lift on the rear 3ph? #2
Could probably figure twice the weight of a rear tiller or box blade. Do you want that in pounds or dollars ?? :D ;)
Seems I recall someone stacking concrete blocks on their 3 ph carry-all to find out what it would handle. Of course, need to counterbalance with weight on the front end.
   / What can a X7xx lift on the rear 3ph? #3
If I remember right the specs are 450lbs one foot behind the arms.
   / What can a X7xx lift on the rear 3ph? #4
The empty pallet! Seriously, it would make the front very light before you reached capacity.
   / What can a X7xx lift on the rear 3ph? #5
I have a 40 gal sprayer that when full probably weighs about 450 lbs. it lifts that with no trouble as long as counter balanced with weight on the front
Quick Attach EZ Axe Skid Steer Tree Shear (A52748)
Quick Attach EZ...
2014 KENWORTH T800 (A52472)
2014 KENWORTH T800...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2007 INTERNATIONAL PAYSTAR 5600I (A52472)
2007 INTERNATIONAL...
