What coolant to add to Max 25
   / What coolant to add to Max 25 #1
ronmar22
Springfield, Illinois
Mahindra Max 25
There seems to be a little confusion (at least I'm a little confused) on exactly what coolant to use top off my Max 25. Has just over 55 hours and coolant is down small amount. After reading (on this site) about putting wrong coolant in and having big problems, I want to make sure. Any input would be appreciated. Dealer has not been a lot of help here.
   / What coolant to add to Max 25 #2
ronmar22,
Open radiator cap (with engine cold) and look at the color of the coolant. If it is GREEN or YELLOW-GREEN, then add a 50/50 mix of Ethylene Glycol to top off. If the color is RED or PINK - RED, then add a 50/50 mix of Propylene glycol. DO NOT mix the two. They are NOT alike. If mixed, they MAY cause damage to the cooling system. If you wish to switch from one to the other, BE SURE to flush out the system VERY good before the change. The only obvious difference is that the RED has a LONGER life cycle than the GREEN. If there isn't much difference in the cost for you, I would change to the RED at a major service time. (I changed mine at the 500 hr service) :2cents: Good luck.
Dave
   / What coolant to add to Max 25 #3
Check the owners manual. Most Diesel engines require a low silicate formula. I use the "Fleetguard" from tractor supply, it is low silicate and approved for diesel service.
ronmar22,
Dave
Thanks. That is what I really expected to hear but wanted reassurance that I was going to do the right thing. It does have the green coolant in it from factory. Thanks again.
I'll check out my local TS for the Fleetguard. Thanks for the info.
   / What coolant to add to Max 25 #6
If you are going to stay with the GREEN, there should be no problems. I would suggest changing to the RED at a major service time. The RED does not have silicates. It is a longer life coolant / antifreeze. You can go LONGER between drain and flush times without the problems caused by silicates. Until retirement, I used the RED in the big trucks I drove for over 15 of the 30+ years I drove. Never had a problem with it.:2cents:
Dave
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
City of Lakeland (A51691)
City of Lakeland...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
7046 (A50322)
7046 (A50322)
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
